Author Topic: RNS 510 Firmware  (Read 11140 times)
Offline coop
Re: RNS 510 Firmware
« Reply #15 on: August 20, 2010, 11:39:25 pm »
Thanks Carl, i had to put the gps arial on the dash for 10 mins and it started to work, I think I need to find a better location for my arial.
pat15312 thanks for the links, do you know any where I can get a maps cd, ive got v6 maps installed but no disk. Also with the camera poi's I believe it dosent worn you when your approaching a camera, if so is it really any use?
Offline coop
« Reply #16 on: August 21, 2010, 09:54:19 am »
Checked the car this morning and I still have the dreaded regensburg syndrome,voice control also still dosen't work. Any other ideas?
smitko
« Reply #17 on: September 19, 2010, 08:51:05 pm »
Hi guys.
I installed 2760 firmware on my RNS and since then I cannot update the maps?!? I insert the new version cd, I confirm "Continue" and then it freeze to "Please wait". I tried to restart the system, I tried different cd's and versions, but all the same.
With the previous SW version I've been always asked if to save the new version or it's only for temporary use.
I'll be gratefull if someone can help me with an advice.
Offline ILoveTuna
« Reply #18 on: September 19, 2010, 09:04:26 pm »
This one if you have above K Revison Gateway.
2760 Firmware
This one if you have below K revsion to stop Battery Drain
2760 No Battery Drain
Does this mean that you dont need a new can gateway and the battery drain issue is fixed by firmware???
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #19 on: September 19, 2010, 09:40:10 pm »
In 99% of cases yes :happy2:
Offline ILoveTuna
« Reply #20 on: September 19, 2010, 10:08:16 pm »
Result... Although has it been tested?  :wink:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #21 on: September 19, 2010, 10:09:38 pm »
Yes i have it running on both of mine no problem  :happy2:
Offline coop
« Reply #22 on: September 28, 2010, 09:07:31 pm »
Hi Guys
update on my regensburg syndrome problem, just took my car to VW today and they have uploaded an older firmware, not sure which one as I no longer have the hidden men, but this has fixed the issue. i'm guessing its 1100 as no sdhc support anymore, but at least the satnav is working now.
