All Things Mk5 > Sat Nav and Car Audio
MFD2 Questions????
<< < (3/3)
aidogti:
Mine was just plug and play, works fine, I put antenna on dash in the middle close to window screen.
vRStu:
It really should be coded to match the car.  You can 'assume' your unit is plug and play because when you plugged it in it worked but that's not Plug and Play really is it.
You can get an idea of the coding from here - http://octavia-vrs.com/cms/content/mfd2-install-guide
There are also some details that might help if you have Aux In.
markfive:
Indeed....
Nonwithstanding the audio side, I would also hazard a guess that if the CAN gateway isn't told to enable controller 37 then when the GPS lock is lost (in tunnels or whatever) the nav will lose position as there is no data from the ABS sensors?
Navigation
[0] Message Index
[*] Previous page
Go to full version
