All Things Mk5 > Mk5 General Area
Mystery message found inside the car......all a bit Scooby Doo....
<< < (5/5)
Golfgirl:
I've got the circles on my front & rear screen too and they are visible when it's misted up....very annoying.
billyboy:
--- Quote from: Steve Baker on March 04, 2009, 03:18:07 pm ---I think the exact same info is on the build data on the White label stuck to the boot floor!  :happy2:
Does anybody know/ have a key to what options etc all the 3 digit codes identify?
--- End quote ---
i had the web link to this , carnt find it now , someone will let you know am sure.
when i put all my numbers in it said i had 19'' wheels,  :surprised:
jd_30:
Here's the weblink for the 3 digit codes. They're actually called PR strings and each and every option and part of the car has a code for it. It also generates the manifest sheet which the car has during build
http://igorweb.org/equidec/Default.aspx
Hope this helps!!
Steve Baker:
--- Quote from: jd_30 on March 06, 2009, 11:05:28 pm ---Here's the weblink for the 3 digit codes. They're actually called PR strings and each and every option and part of the car has a code for it. It also generates the manifest sheet which the car has during build
Hope this helps!!
--- End quote ---
Thanks will give it a try tomorrow!  :happy2:
yin:
I had this mark on mine and removed with  Isopropyl Alcohol
http://cgi.ebay.co.uk/Isopropyl-Alcohol-Propan-2-ol-IPA-250ml_W0QQitemZ260373700150QQcmdZViewItemQQptZUK_HomeGarden_CLV_Cleaning_CA?hash=item260373700150&_trksid=p3286.c0.m14&_trkparms=72%3A1686%7C66%3A2%7C65%3A12%7C39%3A2%7C240%3A1318
Navigation
[0] Message Index
[*] Previous page
Go to full version
