All Things Mk5 > Sat Nav and Car Audio
Airbag Fault After RNS-510 Install?
<< < (2/2)
vRS Carl:
If you can find someone with VCDS they could clear the code for you.
If it is then a problem it will come back. At which point i would then be in to the dealer.
vr6t:
Mine did the same but i think it was part of recoding the new can gateway, i reset it with VAGCOM and it hasn't come back.
QD MBE:
--- Quote from: R32 mad on September 20, 2010, 02:24:57 pm ---I have just installed my RNS-510, as soon as I started the car an Airbag fault appeared in the dispay with a warning light?
Is the installation of the RNS-510 related?
--- End quote ---
As said, airbag indicator centre dash.  Must have turned the Ignition on without it being connected (maybe to test the rns?).
Navigation
[0] Message Index
[*] Previous page
Go to full version
