Author Topic: vRSAlex's Octavia vRS Estate - New Mods On  (Read 309199 times)
Offline vRSAlex
  • -Receive: 253
Re: vRSAlex's Octavia vRS Estate - R8 Calipers now on
« Reply #420 on: November 03, 2012, 01:03:40 pm »
Logs:
Code: [Select]
Friday 2 November 2012 18:25:58:32573 VCDS Version: Release 11.11.4 (x64) Data version: 20120807
1Z0 907 115 A 2.0l R4/4V TFSI     0040
Group A: '003 Group B: '231 Group C: '230
Engine Speed Intake Air Mass Throttle Drive Ignition Pressure Pressure Load Rail Pressure Rail Pressure Rail Pressure
TIME Angle Sensor 1 Timing Angle TIME TIME (specified) (actual) Difference
Marker STAMP /min g/s % °BTDC STAMP bar bar % STAMP bar bar bar
0.04 2800 61 99.6 24 0.12 6 5.87 52.2 0.24 128.17 132.76 -4.6
0.38 3000 83.72 99.6 19.5 0.51 6 6.09 53.3 0.63 129.77 135.97 -6.2
0.76 3200 114.69 99.6 14.3 0.89 6 6.13 57.3 1.02 129.96 134.97 -5.01
1.14 3520 156.89 99.6 6 1.27 6 6.03 64.3 1.41 129.99 127.19 2.79
1.54 3880 173.06 99.6 2.3 1.66 6 6.08 67.5 1.78 129.99 127.24 2.75
1.93 4200 186.17 99.6 3 2.05 6 6.11 70.2 2.17 129.99 130.28 -0.29
2.3 4560 199.53 99.6 8.3 2.44 6 6.11 69 2.56 129.99 131 -1.01
2.69 4880 213.33 99.6 5.3 2.81 6 5.98 74.1 2.95 129.99 135.13 -5.14
3.08 5240 221.36 99.6 9.8 3.2 6 5.99 74.5 3.32 129.99 134.05 -4.06
3.47 5560 231.72 99.6 10.5 3.59 6 5.97 75.3 3.72 129.99 134.92 -4.93
3.85 5880 242.36 99.6 10.5 3.98 6 5.91 80 4.1 129.99 134.77 -4.78
4.23 6160 250.31 99.6 11.3 4.36 5.85 5.83 71.8 4.49 129.99 135.29 -5.3
4.62 6440 253.03 99.6 9.8 4.74 5.63 5.69 62 4.87 129.99 137.12 -7.13
5.02 6720 255.83 99.6 12.8 5.14 5.41 5.08 71 5.27 129.99 140.14 -10.15
122.78 2080 45.47 99.6 6.8 122.92 6 6.23 48.2 122.65 110.58 111.39 -0.81
123.16 2240 50.25 99.6 5.3 123.29 6 6.2 48.6 123.04 115.76 116.62 -0.86
123.56 2400 54.14 99.6 6.8 123.68 6 6.16 49 123.43 121.62 122.96 -1.34
123.95 2560 63.67 99.6 6 124.07 6 6.13 50.2 123.8 127.14 127.62 -0.48
124.32 2720 80.89 99.6 11.3 124.46 6 6.1 52.2 124.19 129.65 131.53 -1.89
124.71 2920 102.81 99.6 10.5 124.83 6 6.07 55.7 124.58 129.95 131.37 -1.42
125.1 3200 132.75 99.6 6 125.22 6 6.05 58.8 124.97 129.99 131.31 -1.33
125.49 3480 159.03 99.6 3.8 125.61 6 5.92 64.3 125.35 129.99 128.57 1.42
125.87 3840 175.92 99.6 3 126 6 5.94 70.2 125.74 129.99 127.67 2.32
126.25 4080 179.14 99.6 6 126.37 6 6.12 67.8 126.13 129.99 128.4 1.59
126.65 4400 190.83 99.6 5.3 126.77 6 6.15 66.7 126.52 129.99 131.69 -1.7
127.04 4680 204.08 99.6 6 127.15 6 6 72.5 126.9 129.99 131.99 -2
127.41 4920 209.31 99.6 8.3 127.55 6 6.03 71 127.28 129.99 131.18 -1.19
127.8 5240 203.5 99.6 9.8 127.92 6 6.02 71 127.68 129.99 133.49 -3.5
128.19 5440 216.06 99.6 12 128.31 6 6.03 70.6 128.07 129.99 134.22 -4.23
128.58 5720 230.39 99.6 11.3 128.7 5.9 5.9 67.8 128.43 129.99 130.38 -0.39
128.95 5960 241.11 99.6 11.3 129.09 5.72 5.73 62 128.83 129.99 133.02 -3.03
129.34 6200 247.28 99.6 12 129.47 5.54 5.19 72.9 129.21 129.99 135.83 -5.84
129.73 6440 252.44 99.6 12.8 129.85 5.36 5.23 62.7 129.6 129.99 132.3 -2.31
Code: [Select]
Friday 2 November 2012 18:39:27:32573 VCDS Version: Release 11.11.4 (x64) Data version: 20120807
Group A: '004 Group B: '020 Group C: '031
Engine Speed Voltage Supply Coolant Intake Air Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition Lambda Sensor Lambda Sensor
TIME Temperature Temperature TIME Angle Delay Angle Delay Angle Delay Angle Delay TIME Current Value Specified Value
Marker STAMP /min V °C °C STAMP °KW °KW °KW °KW STAMP
0.25 1600 14.1 79 25 0.04 0 0 0 0 0.13 1.04 1
0.64 1680 14.194 79 25 0.39 0 0 0 0 0.51 1.11 0.95
1.03 1800 14.194 79 25 0.76 0 0 0 0 0.9 0.96 0.91
1.43 1960 14.194 79 25 1.15 0 0 0 0 1.28 0.91 0.91
1.8 2080 14.288 79 24 1.54 0 0 0 0 1.67 0.89 0.91
2.19 2240 14.194 79 24 1.93 0 0 0 0 2.06 0.89 0.91
2.57 2400 14.1 79 24 2.31 0 0 0 0 2.45 0.88 0.9
2.97 2560 14.1 79 24 2.7 0 0 0 0 2.82 0.86 0.88
3.34 2720 14.194 79 24 3.09 0 0 0 0 3.21 0.87 0.88
3.73 2960 14.194 79 24 3.48 0 0 0 0 3.6 0.86 0.86
4.12 3240 14.194 79 24 3.85 0 0 0 0 3.99 0.85 0.84
4.51 3520 14.194 79 24 4.24 0 0 0 0 4.37 0.79 0.79
4.88 3800 14.1 79 23 4.63 0 0 -3 0 4.76 0.77 0.78
5.28 4120 14.194 79 23 5.02 0 0 -3 0 5.15 0.75 0.77
5.67 4440 14.1 79 23 5.4 0 0 -3 0 5.54 0.76 0.77
6.05 4720 14.1 79 23 5.79 0 0 -3 0 5.91 0.77 0.79
6.43 5040 14.1 79 23 6.18 0 0 -2.3 0 6.3 0.78 0.8
6.82 5320 14.1 79 23 6.57 0 0 -1.5 0 6.69 0.81 0.82
7.21 5600 14.1 79 24 6.94 0 0 -1.5 0 7.08 0.81 0.82
7.6 5880 14.194 79 24 7.33 0 0 -1.5 0 7.46 0.8 0.82
7.97 6160 14.1 79 24 7.72 0 0 -0.8 0 7.85 0.8 0.82
8.36 6400 14.194 79 24 8.11 0 0 0 -0.8 8.24 0.81 0.82
8.75 6640 14.1 79 25 8.49 0 0 0 -0.8 8.63 0.8 0.82
9.15 6880 14.1 79 25 8.87 0 0 0 -0.8 9 0.8 0.82
52.03 1640 14.1 77 25 52.15 0 0 0 0 52.28 0.98 1
56.29 1840 14.194 77 25 56.41 0 0 0 0 56.16 1.12 0.97
56.68 1920 14.194 77 24 56.8 0 0 0 0 56.55 0.95 0.91
57.07 2040 14.194 77 24 57.19 0 0 0 0 56.92 0.91 0.91
57.44 2160 14.194 77 24 57.58 0 0 0 0 57.31 0.89 0.91
57.83 2320 14.194 77 24 57.95 0 0 0 0 57.7 0.89 0.91
58.22 2480 14.1 77 24 58.34 0 0 0 0 58.09 0.87 0.89
58.61 2640 14.1 77 24 58.73 0 0 0 0 58.47 0.85 0.88
58.98 2840 14.1 77 24 59.12 0 0 0 0 58.85 0.87 0.87
59.38 3080 14.1 77 24 59.5 0 0 0 0 59.25 0.84 0.85
59.77 3400 14.1 77 24 59.88 0 0 0 0 59.64 0.8 0.78
60.16 3680 14.1 77 24 60.28 0 0 0 0 60.01 0.8 0.79
60.53 3960 14.1 78 24 60.67 0 0 0 0 60.4 0.77 0.79
60.92 4280 14.1 78 24 61.04 0 0 0 0 60.79 0.77 0.78
61.31 4600 14.1 78 23 61.43 0 0 0 0 61.18 0.79 0.8
61.7 4880 14.1 78 23 61.82 0 0 0 0 61.56 0.77 0.77
62.08 5200 14.1 78 24 62.21 0 0 0 0 61.94 0.78 0.8
62.46 5440 14.194 78 24 62.59 0 0 0 0 62.34 0.8 0.82
62.85 5760 14.1 78 24 62.98 0 0 0 0 62.73 0.8 0.82
63.24 5960 14.006 78 24 63.37 0 0 0 0 63.1 0.81 0.82
63.62 6200 14.1 78 25 63.76 0 0 0 -0.8 63.49 0.8 0.82
102.29 3160 14.1 74 20 102.43 0 0 0 0 102.56 0.96 0.93
102.68 3280 14.1 74 20 102.8 0 0 -3 0 102.94 0.84 0.83
103.07 3400 14.194 74 21 103.19 0 0 -3 0 103.31 0.79 0.8
103.46 3600 14.1 74 21 103.58 0 0 -3 0 103.7 0.77 0.77
103.84 3760 14.194 74 21 103.98 0 0 -3 0 104.1 0.77 0.78
104.22 3920 14.1 74 21 104.34 0 0 -3 0 104.48 0.75 0.77
104.61 4080 14.1 74 21 104.74 0 0 -2.3 0 104.86 0.79 0.8
105 4240 14.006 74 21 105.12 0 0 -2.3 0 105.25 0.79 0.79
105.38 4400 14.1 74 21 105.52 0 0 -1.5 0 105.65 0.79 0.8
105.77 4560 14.1 74 21 105.89 0 0 -0.8 0 106.04 0.8 0.8
106.16 4720 14.1 74 21 106.28 0 0 -0.8 0 106.4 0.8 0.81
106.55 4920 14.1 74 22 106.67 0 0 0 0 106.79 0.8 0.81
106.93 5040 14.1 74 22 107.07 0 0 0 0 107.19 0.81 0.82
107.31 5200 14.1 74 22 107.43 0 0 0 -1.5 107.58 0.8 0.82
107.71 5360 14.1 74 23 107.83 0 0 0 -1.5 107.95 0.81 0.82
108.09 5480 14.006 74 23 108.22 0 0 0 -1.5 108.34 0.87 0.9
108.47 5480 14.1 74 23 108.6 0 0 0 0 108.73 0.95 0.98
108.86 5440 14.1 74 21 108.98 0 0 0 0 109.12 0.95 1
109.24 5360 14.1 74 20 109.37 0 0 0 0 109.49 1.06 1
109.64 5320 14.1 74 20 109.76 0 0 0 0 109.89 1.27 0.95
110.02 5280 14.1 74 20 110.15 0 0 0 -0.8 110.27 0.92 0.88
110.4 5320 14.1 74 20 110.52 0 0 0 -2.3 110.67 0.8 0.8
110.79 5440 14.1 74 21 110.92 0 0 0 -2.3 111.04 0.8 0.81
111.19 5560 14.1 74 22 111.3 0 0 0 -1.5 111.43 0.79 0.81
111.56 5720 14.1 74 23 111.7 0 0 0 -1.5 111.82 0.81 0.82
111.94 5840 14.006 74 23 112.07 0 0 0 -0.8 112.21 0.8 0.82
112.33 5960 14.1 74 24 112.46 0 0 0 -0.8 112.58 0.8 0.82
112.73 6080 14.006 74 24 112.85 0 0 0 -0.8 112.97 0.81 0.82
113.1 6200 14.1 74 24 113.24 0 -0.8 0 0 113.36 0.82 0.82
113.49 6360 14.1 74 25 113.61 0 -0.8 -0.8 -0.8 113.75 0.8 0.82
Follow AKS tuning on Facebook
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #421 on: November 03, 2012, 01:46:12 pm »
Dips in fuel?
Diesel Daily Hack.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #422 on: November 03, 2012, 02:48:28 pm »
Have you measured the flow of the other OEM pump? 300l/h?  :smiley:
Tbh I havent measured the flow.  Going to log the pressures in a bit.
PM sent   :drinking:
Over the top mod list ;o)
« Reply #423 on: December 04, 2012, 08:00:45 pm »
Ive been wanting to make up a solid bush to replace the smaller dog bone rubber bush for ages now.  The standard one splits really easily and the powerflex seems a compromise.  With a solid one not available I thought why not.  Its not fitted yet so testing will start on monday.  If im happy with it then I (personally) will make a batch of ten to sell (who is up for a group buy maybe) :happy2:  The bush is made of aircraft grade alloy.
....I finally got around to reading your build thread and noticed this ^.
Did you make any more and would one fit my Mk5 GTI's BSC dogbone (or is it BCS?)?
I already have all three VWR engine mounts (not the solid metal versions) and was thinking of using a polyurethane bush so that all my car is poly bushed.
EDIT:
I've just read your reply to these questions later in your thread. So do you have any for sale, please?
« Last Edit: December 04, 2012, 08:05:06 pm by RedRobin »
Offline vRSAlex
  • -Receive: 253
« Reply #424 on: December 04, 2012, 08:38:14 pm »
In the end I swapped this one out for a vibratechnics version.  It's a rubber version.  I keep them in stock.
Yours the stock arm from factory?
« Reply #425 on: December 04, 2012, 08:51:49 pm »
....No, it's black and badged BCS BHS but I don't have any pics of it. I think BCS got eaten by Revo?
This pic was taken when I had the OEM arm fitted with the 'VWR' (Vibratechnics?) lower engine mount:
It's so unlike me not to take a photo of any mod on my car. I don't even know which bush is fitted - Either OEM or Powerflex.
« Last Edit: December 04, 2012, 09:22:15 pm by RedRobin »
Offline vRSAlex
  • -Receive: 253
« Reply #426 on: December 04, 2012, 09:19:42 pm »
You have the BSH mount.  I can't confirm if the vibratechnics mount would fit into it though.
« Reply #427 on: December 04, 2012, 09:25:18 pm »
Perhaps I'm getting confused (again!) - It's the bush (if there is one) in the BHS arm at the forward end which is bolted(?) to the black arm in my photo above.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=72p5boldio3d7gsveb4s8301ge&/topic,19740.0.html
« Reply #428 on: December 04, 2012, 09:33:40 pm »
The middle of the three bolts robin. The bolt on the left doesnt have a bush
« Reply #429 on: December 04, 2012, 09:48:30 pm »
....That's what I thought might be the case, Rich  :drinking: So that middle bolt does have a bush in the forward end of the dogbone (now BHS on mine).
« Reply #430 on: December 04, 2012, 09:49:11 pm »
Do you mean BSH Robin?
« Reply #431 on: December 04, 2012, 09:50:45 pm »
....That's what I thought might be the case, Rich  :drinking: So that middle bolt does have a bush in the forward end of the dogbone (now BSH on mine).
Yes.. its pressed into the dogbone
h4rdy
Re: BDMAlex's Octavia vRS Estate
« Reply #432 on: January 27, 2013, 10:26:53 am »
These turned up last week.  Now I just need to get a day off to get them fitted.
Hello mate hows it going?
I know I trawled back a bit but are you running a 20mm or 21mm wrist pin now?
I can't find the 21mm pin rods did you have them specially made?
Have you got a standard KO4 piston in? It is an XBOW one still yes?
Thats another issue as I can't find a 21mm pin Piston either.
I think I know the answer to this as I asked you but will the pistons fit past the crank from underneath or is it defo a head off exercise?
Offline vRSAlex
  • -Receive: 253
« Reply #433 on: January 27, 2013, 10:40:52 am »
The rods in the car are 20mm pinned matched with almost new stock pistons and brand new rings.
I do 21mm rods now from DM Forged.  They are still the only company to make them.  Just stick with stock pistons.   Ive not seen 21mm aftermarket pistons.
Head off to do them.
No need to do rods on ED30 lump unless going to 450 onwards.
h4rdy
« Reply #434 on: January 27, 2013, 10:48:17 am »
Cheers ill probably get a new set of oem Pistons unless I get the JE custom option from IE.
Have fun....
