All Things Mk5 > Sat Nav and Car Audio
Weird RNS 510 version C / Skoda Bluetooth Problem
<< < (8/8)
vRStu:
Just keep us posted.
flyboy1976:
Now this is messed up! Problemo solved
i disconnected the mdi kufatec lead so it was just the oem harness and my bluetooth harness and it worked. plugged it back in again and it worked also. But before i done this i deactivated aux monitoring in vcds under controller 37. Weird this was but all sorted now however the company i went to see said dodgy connection! On a kufatec lead?
vRStu:
Is this with the 77 code I told you to use??
What happens if you put 77 back to the code you previously had?
flyboy1976:
Na coding made no difference! but glad ive got it sorted though. cheers you guys have been very helpful....thanks so much  :notworthy:
vRS Carl:
Glad you got it sorted mate  :happy2:
Always the simplest of things that stump people for ages
Navigation
[0] Message Index
[*] Previous page
Go to full version
