All Things Mk5 > How to Guides / Troubleshooting
Aux input/CD - MFD2
cartwheel:
The DVD version (I guess, it's got a front loader thy the nav disc goes into.
I'm not blessed with much technical knowledge!! :confused:
Norbreck21a:
Right, been reading my user manual for the DVD version of the MFD2, and there are possibly a couple of things you can try.
Firstly, the add on tuner is controlled by the AUX input. This is activated or de-activated as follows (assuming you have access to this menu)
Press the CD Button, and then on the lower right hand side press SET UP to open the main AUX menu.
From here you have a choice of activating or de-activating the AV or AUX sources. For AV you will have the choices - A+V, AUDIO or OFF. For AUX the choices would be - AUDIO or OFF. Turn the AUX to OFF, this should de-activate the tuner and give you control back over your CD player.
The only other option I can think off (short of taking the unit out and unplugging the tuner, is to reset the MFD2 to factory defaults. I'm not sure if this will wipe your pre-sets, but that's no real big deal anyway.
To do a factory Re-set, first press the INFO button (at the bottom left of the MFD2)
Then press SYSTEM SETTINGS to open the main menu for system settings.
In the top right hand corner will be a FACTORY SET button. Pressing that resets the unit to factory default (and hopefully turns off the AUX input that you can't reach through the CD screen). According to the manual, routes, addresses and destinations that you have stored will NOT be deleted.
Thats all I can think of for now. Good luck.
coolhandluke:
--- Quote from: cartwheel on October 10, 2010, 12:38:54 pm ---I've got a freeview tuner installed on my MFD2 which was done by the previous owner. However it seems to overide the cd function as they both accessed via the cd button.
Any ideas?
--- End quote ---
Any idea whats involved in installing a Freeview tuner?
Is it something thats best left to the experts and can you still use the CD player?
aidogti:
thanks Norbreck21a, i read your reply as im having trouble with my mfd2 and an ipod lead i installed through the video imput... the problems i was having was the ipod kept pausing and any time i came to a stop the safety msg would appear bout viewing this while moving... annoying!!! but i did what norbreck said and it has seemed to work, went on a little spin and no safety msg or pausing....`the AV was set to A+V so i just changed it to audio, thanks again.. :happy2: :drinking:
GeeTeeI:
Sorry folks, but I too would be interested to know how one can get a tv function to work on my MFD2.
Is it easy to do?
Navigation
[0] Message Index
[*] Previous page
Go to full version
