Author Topic: Vag DPB Paint polish and pads, which ones ?  (Read 3100 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« on: November 06, 2010, 06:11:47 pm »
Hi, i was just wondering what the best polish / pad combo was for use on my black mk5, it will be applied on the DAS-6 and the golfs paintwork is pretty good.
It has some light swirls and a couple of randomly placed deeper scratches but im happy enough to just take the rough edges off them and keep my top coat nice and thick.
ive been thinking about menzerna super finish on a polishing pad followed by final finish on the finishing pad ?
any advice appreciated !
Ta Bryan !
MK7 GTI - ARRIVING DECEMBER
Offline Drapoon
Re: Vag DPB Paint polish and pads, which ones ?
« Reply #1 on: November 08, 2010, 08:02:23 pm »
Hi fella
I used the menzerna super finish once on my solid balck gti & ....never again. It left cloudy hazing all over the paintwork - spoke to a semi pro detailer & apparently that particular polish can react badly in certain temperatures. I have been using 3m fast cut plus on a 3m green pad followed by the menzerna final finish on blue 3m pad with great results. Hope this helps
See below the thread where we resolved the hazey paintwork!
http://www.detailingworld.co.uk/forum/showthread.php?t=176155
« Reply #2 on: November 08, 2010, 08:56:29 pm »
Menzerna can be temperature sensitive but when worked properly are brilliant. I've always go for menzerna polishes with either 3M Megs or Lake Country pads.
« Last Edit: November 08, 2010, 11:05:36 pm by stealthwolf »
  • -Given: 64
  • -Receive: 48
« Reply #3 on: November 08, 2010, 09:23:54 pm »
 :happy2: ive got a little bit hazing on one of my doors i wonder if this is due to it being polished previously ? are you not a fan of the menzera polish then ?
I might go for the meguires, 83, 80 & 82 on finishing and polishing pads, its not too bad so this should do the trick
« Reply #4 on: November 08, 2010, 11:06:13 pm »
Hazing could be anything. I used to get hazing from not letting Supernatural cure enough before buffing hence it would "gas" or form a haze.
GTIStevie
« Reply #5 on: November 10, 2010, 03:54:52 pm »
I just did my car at the weekend and I used menzerna intensive polish on either a polishing pad or compounding pad the followed up with final finish on a finishing pad results were great although I don't have any pics but I'm very pleased with the results.. I topped mine of with a coat of nanolex nano wax which makes it look even better. This was on red but I'm sure it would be the same on DBP.
Menzerna polishes are very good for hard German paint most people I've spoken to had recommended it to me and had some good advise for guy at polished bliss.
« Reply #6 on: November 10, 2010, 04:28:14 pm »
I have a diamond blac pearl car too and used only the final finish polish with a finishing pad. The end result was immense.
Offline keith
« Reply #7 on: November 10, 2010, 10:06:15 pm »
I like the 3m pads with megs#205, Craigy says good results with #105 but I havent used it yet.
