Author Topic: Very Basic Question  (Read 2708 times)
Offline POC
Very Basic Question
« on: November 13, 2010, 05:11:46 pm »
Just being lazy here.  I need to sling some oil in the gti to bring the level up a little.  Question is, what weight oil should I put in?  The car is new to me and I have no idea what would be in there already.
Thanks, Paul
Re: Very Basic Question
« Reply #1 on: November 13, 2010, 05:15:01 pm »
It should be in your manual. I'm assuming you drive a GTI, in which case it's 5W-30. Avoid Quantum and Mob1l. Stick to Castrol stuff.
Offline skifast
« Reply #2 on: November 13, 2010, 06:32:35 pm »
as quantum is the oil supplied by tps ,vw's own parts supply business i am intrested to know why you wouldnt recommend it?
« Reply #3 on: November 13, 2010, 06:51:42 pm »
Ask them if they are VW504 approved. Specifically those words. Not "recommended" for, not "accepted", "504 approved".
Have a read of:
PDF clicky
clicky 2
clicky 3
clicky 4
clicky 5
clicky 6
Offline gti265
« Reply #4 on: November 14, 2010, 12:22:14 am »
it might be 10w40 i no it should be 5w30 culd also be semi/part or full synthetic but would be worth double checking before you put the wrong stuff in, ring previous service garage, or get a full oil change :)
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline G60s GO
  • Edition 30, Plaque No.0100
« Reply #5 on: November 14, 2010, 02:39:53 am »
If you have a GTI, it's 5W-30 but make sure you buy Castrol EDGE as this is recomended and approved by Vw "504 Standards" or something. IT's also compatible with the Longlife Service.
But as mentioned, this should be in your Manual :happy2:
  Perfection Is Perfectly Simple; Fouling Things Up Requires true skill.
Offline POC
« Reply #6 on: November 14, 2010, 07:09:08 pm »
Thanks guys, I think I may just drop the oil and do a full change myself.  I assume its a pretty straight forward job?
Offline gti265
« Reply #7 on: November 14, 2010, 10:59:37 pm »
it doesnt have to be 5w-30 i no mine is 10w-40
Offline POC
« Reply #8 on: November 17, 2010, 02:59:46 pm »
Thanks guys, I did a full oil change myself today.  Used castrol Edge 5-30, along with a genuine filter/replacement sump plug.
Offline Mr Punch
  • Has Pulled Cables At A Resonable Level
« Reply #9 on: November 17, 2010, 10:50:19 pm »
Hi why are you using 10w - 40 ????
I thought it was 5w-30
I Always Wanted A Black Golf GTI Now I Have One...Yippee
Offline gti265
« Reply #10 on: November 18, 2010, 12:35:54 am »
yer its ment to be 5w30 but the last time i had it serviced that was what was put in,
 but its being changed next month to 5w-30,
 i just thought id point out so he didnt put the wrong stuff in, although i no you can mix the oils well up to 0.5 of a litre anyways without problems.
tom
Offline gti265
« Reply #11 on: November 19, 2010, 01:14:01 pm »
also i have a bottle of the quantum 5w-30 oil at home and on the front it clearly states that its VW 504/507 approved, so there should be no problem with using quantum oil from tps
tom
