General > Detailing
Stripping Old Wax
stealthwolf:
APC will do a similar job, but if you're prepping the wheels, may as well make sure they're very clean.
andrewparker:
Clay it is then. Tell me what I need!
stealthwolf:
The detroits are fairly simple to clean. I used dodo juice born to be mild shampoo through a lance, rinsed, clayed with sonus green and some quick detailer (megs smooth surface should be okay I think and can be bought from halfrauds). Rinse, dry with a towel and then apply the sealant. I used two coats of Poorboy's Wheel Sealant using a foam applicator, buffed and then two laters of collinite, 15-20 mins apart.
alan_n:
Daisy apc is good value for money and will do the job no problem
swf7y:
I hear Fairy liquid is great for stripping wax. Howeber, only use a small amount as it is a very strong degreaser.
Navigation
[0] Message Index
[*] Previous page
Go to full version
