Author Topic: Mark's Steel Grey Edition 30 *Dyno Results on Page 3!*  (Read 27886 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=j4hmue6fi9iji6v4cr0tvvokhi&/topic,19740.0.html
Re: Mark's Steel Grey Edition 30
« Reply #15 on: January 27, 2011, 12:01:00 am »
there you go
Offline coupekidd
« Reply #16 on: January 27, 2011, 07:39:11 am »
Georgous GTi mate!!! :drool:
Its like my steel grey GTi on steroids :signLOL:
Offline marka87uk
« Reply #17 on: January 28, 2011, 08:31:03 pm »
Cheers! Looks good with the Edition badge on the grille... Do you have any other pics of that and how does it fix on?
Steel Grey Edition 30 DSG
« Reply #18 on: January 28, 2011, 08:34:50 pm »
If you get an edition 30 badge (the one thats meant for the boot) from either ebay or the dealers, it sticks straight on with the adhesive strip on the back
« Reply #19 on: February 12, 2011, 09:12:19 am »
Looks to be a great spec.
I was wondering what the black circle was too!  :grin:
Offline johnston
« Reply #20 on: February 14, 2011, 07:27:22 pm »
Loving you anni, great colour choice on the ED30  :happy2:
Offline marka87uk
« Reply #21 on: March 19, 2011, 01:23:53 pm »
I haven't got much to update at the moment but I recently upgraded the firmware of my RNS510 to the modified 2760 version and it all went smoothly thanks to the guide on here! :happy2:
The modified version works perfectly without any battery drain on my (I assume) K version CAN-BUS, and enables other features too such as the test menu.
I just need to obtain the v7 maps now for full 7-digit postcode search (preferably not at the cost VW charge for them!).
Offline marka87uk
« Reply #22 on: April 02, 2011, 04:46:49 pm »
Time for a proper update... :smiley:
I bought a US spec grill courtesy of damo666 on here, and he was even kind enough to throw in the black badge too! :happy2:
It left me thinking of what to do about the front number plate and so I decided the best method would be to use magnets as others have done.
Here's the parts ready to be assembled:
I used neodymium N42 magnets with a pull of 6.4kg. Do not do end up getting them all stuck together like I did as they are a PITA to get apart again!
Firstly I glued on the magnets to the number plate, spacing them about 11cm apart:
Then I covered them with weatherproof cloth tape which helps in keeping them secure too:
Next I held up the plate to the grill where I wanted it to go and placed the magnets on the back:
I then removed them one at a time to glue into place and finally covered them again with weatherproof tape:
And here's the finished shots!  :pomppomp:
Do you have a pic of the number plate on, especially the top view so we can see how the plate is attached to the grille?
Offline marka87uk
Here's a couple of the plate attached (excuse the dirtyness of the car!) - I'll take a picture from above tomorrow.
They are 5mm magnets so the plate sticks out slightly but not much; less than it would with the standard holder on anyway! :smiley:
Offline mattyw
my mates private plate is one digit different to yours N7 MDA
Offline Verity
Love the idea of using magnets. I've not seen that before
Really really gorgeous car!
Did you curve the plate or is it flat and hence sticks out at the edges? Sorry, on Iphone so pics don't come out great. I think topcat had to curve his number plate.
Offline marka87uk
It's a standard plastic plate so bends correctly as I've spaced out the 5 magnets in a line.
Top Cat was using a metal plate, and that's why I'm assuming he had to bend it. :happy2:
Offline marka87uk
Here are a few more pics as requested. :happy2:
