Author Topic: Can anyone identify this part please.  (Read 9739 times)
Offline jimmy-s3
« on: April 23, 2011, 01:30:44 pm »
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: Can anyone identify this part please.
« Reply #1 on: April 23, 2011, 01:36:38 pm »
My guess is sensor for the cam position  :confused:
Over the top mod list ;o)
Offline jimmy-s3
« Reply #2 on: April 23, 2011, 03:26:03 pm »
Thanks but....
Anyone got a more definate answer?
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: April 24, 2011, 09:53:51 am »
Its the VVT sensor/actuator.
Follow AKS tuning on Facebook
Offline a89
« Reply #4 on: April 24, 2011, 11:22:06 am »
Anyone know how much these are? Mines snapped like that one.
Offline jimmy-s3
« Reply #5 on: April 24, 2011, 11:42:16 am »
VVT sensor/actuator?
As in Vairiable valve timing?
What would the effects of this not working be?
« Last Edit: April 24, 2011, 11:53:26 am by jimmy-s3 »
Offline TrickGTI
« Reply #6 on: April 24, 2011, 12:48:53 pm »
reduced performance mainly. VVT variable valve timing. it basically alters when the valves open mostly at higher revs . best car to feel this working on is properly a civic tyre r i think most people have being in one of them  :smiley:
2006 Tornado red GTI
Offline jimmy-s3
« Reply #7 on: April 24, 2011, 12:51:21 pm »
Cheers!
I think that may be the cause of my car not running as smooth in the higher rev range!
Can anyone provide me with a part number for this?
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #8 on: April 24, 2011, 06:51:31 pm »
Did a fault code not come up for this?  Its obviously damaged but its maybe just the casing thats damaged and the internal wiring is still OK?
Would make sense if you're having issues though.
Is there a thread with the issues you are having?
Sepang Blue S4 BE Avant
Offline jimmy-s3
« Reply #9 on: April 24, 2011, 07:09:30 pm »
No fault code came up!
Im not sure if the wiring is damaged or not?
Theres two wires that i can see and one of the looks like its oxidising(gone green).
I cant find any other threads with this problem either!
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #10 on: April 24, 2011, 07:22:28 pm »
I mean do you have a thread with the issues you're having?
Offline jimmy-s3
« Reply #11 on: April 24, 2011, 08:15:03 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,25065.0.html
Id started this thread a while back.........
Offline jimmy-s3
« Reply #12 on: April 26, 2011, 08:39:33 am »
Whats the part name for this? I want to order this part today but not sure the correct name for it?
Offline vRSAlex
  • -Receive: 253
« Reply #13 on: April 26, 2011, 09:39:53 am »
Just try VVT unit/sensor.
Offline alexperkins
  • -Receive: 99
« Reply #14 on: April 26, 2011, 09:46:33 am »
ETKA often lists these along the lines of Camshaft Timing Actuator  :happy2:
