Author Topic: SteveP's New Project  (Read 356863 times)
Offline luckyGti
  • -Receive: 27
Re: SteveP's New Project
« Reply #510 on: September 02, 2011, 10:09:54 pm »
A review was my next question   :wink: look forward to it :happy2:
Offline chungster
« Reply #511 on: September 02, 2011, 10:12:40 pm »
I've only just noticed - is the cover plate made by Sachs??
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #512 on: September 02, 2011, 10:14:53 pm »
Yep it stamped Sachs, which did surprise me  :happy2:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #513 on: September 02, 2011, 10:31:27 pm »
kit does look cool, by the looks of it its a SMF ?
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #514 on: September 02, 2011, 10:33:12 pm »
Oh yes, SMF FTW   :party: :party:
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #515 on: September 03, 2011, 09:02:37 pm »
Couple more additions today
New Rev N PCV, mine was still on the original one from 2005 and was starting to idle a little rough, this has sorted that problem one.
Also couldn't believe the difference in the old vs. new PCV, the new one feels like it's twice as heavy and much better built than the original one, so VW do listen sometimes  :grin:
Also fitted the Draft 42 boost tap (thanks Keano  :happy2:) and linked it up to the PLX boost sensor ready for setting it up with my wifi OBD-II monitor on the iPad  :party:
And finally swapped the 225/40/18 Hankook RS2's tyres over to some 235/40/18 Dunlop Sport Maxx TT's, should give some much needed grip for the wet track days :driver: :driver:
« Reply #516 on: September 03, 2011, 09:06:48 pm »
How much is the new revision PCV?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #517 on: September 03, 2011, 09:12:09 pm »
£34 inc VAT  :happy2:
« Reply #518 on: September 03, 2011, 11:02:35 pm »
How easy is it to change the PCV?
« Reply #519 on: September 04, 2011, 12:47:36 am »
wow... you clutch whore! custom painted to match the wheels! haha!
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #520 on: September 04, 2011, 07:23:50 am »
2 clip on pipes and 4 x T25 screws once you have got the engine cover off  :happy2:
« Reply #521 on: September 04, 2011, 08:14:01 am »
Sounds like the hardest bit. Unfortunately!  :sad1:
Wonder if it's worth doing for the sake of it. Anything else I need or do I just walk into VW with that part number?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #522 on: September 04, 2011, 09:29:01 am »
^^^^^^^^^^@ Stealthhttp://vagdrivers.net/forums/index.php?showtopic=40537 HTH :happy2:
Edit: Just need the newer N revision :smiley:
« Reply #523 on: September 04, 2011, 09:34:21 am »
Steve, did you go from BSH catch can to lastest REV PCV?  Did you have any issues while using the BSH you was trying to rule out?
 :drinking:
Offline NeilM
« Reply #524 on: September 04, 2011, 06:36:03 pm »
The bar for the wheels is a good idea Steve, I guess you needed it to get above the battery, it would make my wheels alot easier to hold in the back, you could even put clamps on the ends to hold them in the middle.
Will you get 4 wider wheels across the back? Mine looks a bit tight.
You know when I see those wheels I'll be getting the colour chart out  :happy2:
