All Things Mk5 > Performance Modifications
S3 hubs - help and advice needed please folks.
scopes:
S3 - N 910 849 01 = M14x1, 50x55 would 2 off these bolts be required then one for each side?
vs
GTI - N 909 488 02 = M14x1, 50x35
Also what else would be required to change to s3 hubs & wishbones?
thanks
the bruce:
collar nuts
scopes:
Hey Bruce cheers :drinking:
would they also be known as wide nuts with the washer built in?
also would the gti bearings fit in ok, any part numbers
thanks
the bruce:
cheers mate !!
Yes, "wider" nuts with the washers built in. Bear in mind stock GTI nuts also are 'collar type',
but S3 ones have a wider collar.
Yes, your current bearings still fit.
scopes:
nice one dude
would it be worth while just changing the bearings, haven got that far?
Navigation
[0] Message Index
[*] Previous page
Go to full version
