Author Topic: What did you and your MKV do today?  (Read 3927300 times)
Offline njr911
« Reply #12405 on: June 21, 2022, 12:32:22 pm »
Had it valeted in preparation for selling it :(
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #12406 on: June 21, 2022, 09:06:12 pm »
Did a compression test.  120psi across the board.  Time to dump it off to WBAC I think  :grin:
:scared: That's very close to its lower limit of 101.5 psi (7 bar).
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #12407 on: June 21, 2022, 09:06:55 pm »
:signLOL:
What's the lowest reading that's still ok ?
The BPY here in the states is the same is BWA - 101.5 psi (7 bar).
« Last Edit: June 22, 2022, 04:14:12 am by ROH ECHT »
Offline OllieVRS
  • -Given: 17
« Reply #12408 on: June 22, 2022, 01:02:20 am »
Jaysus that's rough. I don't know the specifications for ED30s, but this is what I found for normal GTIs a while back, I can't find the source of the info though
Quote
VW says it should be 170psi+ for new engine and it's time for a rebuild under 109 psi
Provided your compression tester isn't faulty, are there any problems otherwise with how the car drives? Have you had any metal flakes in the oil filter?
'06 Skoda Octavia vRS TFSI
Offline Lewo
« Reply #12409 on: June 22, 2022, 12:04:54 pm »
Noticed yesterday that after fitting the front seats the other day,
that the drivers window now works with one touch to fully open & close.
After fitting the window regulator last year it had stopped doing that and was a pita lol.
Must be having the battery disconnected for an hour maybe reset something?  :rolleye:
  • -Receive: 692
« Reply #12410 on: June 22, 2022, 01:40:48 pm »
Quote
Ah OK, so I've got 11psi left before rebuild time  :grin:
It could be the tester so I'll order another one and get a second opinion, as it were.
As for symptoms, it's just completely gutless off boost, and not brilliant in boost either.  The throttle pedal just feels like stepping on a bath sponge.  Squishy and lifeless.  Zero response. It's had a new turbo 1500 miles ago, so it's not that. There were tiny gold coloured flecks at the last oil change, which looked turbo thrust bearing colour to me, hence the turbo swap.  But no steel or rod bearing material flakes.
It also struggles to hold the usual 800rpm idle when hot.  The longer it idles, the slower it gets, almost down to 600.  A few times last week when sat in traffic, the idle dropped down to 400ish, bounced back to 800, then again to 400, and so on.  It seems like an injector is dropping out intermittently.  The current set are 80K miles old so wouldn't surprise me. I'm loathe to spend £800 on injectors if the compression is that low.  Engine is going in the bin if that really is the case, well, the whole car will be!
If I stop the engine and restart it, it's perfectly smooth again like nothing happened!  And from cold, it starts on the button and drives absolutely fantastic, almost like a new engine.
If not compression related, it's obviously something electrical but there are never any fault codes when it acts up.  Hence why it's had the parts cannon fired at it so many times over the years and believe me, this ungrateful b1tch of an engine has wanted for nothing!  There is literally is nothing left to replace, except the block & head!
All 4 plugs are dry and the same colour.  It's just unusual to see the whole bank that low on compression, and all at exactly 8.3 bar or something......so maybe it is a sh1tty tester. It's a cheap Gunsons one I bought years ago.  But saying that, the same tester measured 14 bar across the board a few years back, so I dunno......it's puzzling.
« Last Edit: June 22, 2022, 01:42:48 pm by Pudding »
Offline GilesWoodward59
« Reply #12411 on: June 22, 2022, 04:08:44 pm »
Head gasket, piston ring wear and timing belt / chain stretch can all be causes of low compression across all cylinders. Presume you’ve ruled these out? Also checking  your tester isn’t faulty would be a good plan!
Edition 30 - No. 1233
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bdhc5ne5hns06babjbrfglc3q1&/topic,19740.0.html
« Reply #12412 on: June 22, 2022, 07:58:28 pm »
2.5T conversation pudding?  :party:
  • -Receive: 692
« Reply #12413 on: June 23, 2022, 11:21:30 am »
I did consider the timing could be off because I replaced the chain/VVT stuff not long ago.  For that to be far off enough to affect the valve timing, the ECU would moan about cam/crank correlation and the VVT measuring blocks in VCDS would be off.  Good shout though  :happy2:  I'll double check the timing when I get a chance.
Defo not the head gasket and I've ordered another tester.
  • -Receive: 692
« Reply #12414 on: June 23, 2022, 11:22:55 am »
Nice idea, but there's no way I would put that in a FWD car  :grin:
  • -Receive: 692
« Reply #12415 on: June 25, 2022, 12:12:24 am »
You were right, the tester was bad.  Mister second opinion measured 14 bar across all the whole bank, so back to the drawing board, but I'm relieved the engine isn't fooked.
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #12416 on: June 25, 2022, 12:48:02 am »
Great news Kev ref engine!
« Reply #12417 on: June 25, 2022, 03:01:21 pm »
The hunt continues!! Glad to hear it’s been saved from the WBAC knackers yard
  • -Receive: 692
« Reply #12418 on: June 25, 2022, 03:50:18 pm »
Cheers chaps.  WBAC quoted me £1800 for the Eddy by the way  :grin:
Offline bobby_fodge
  • -Given: 22
  • -Receive: 39
« Reply #12419 on: June 25, 2022, 07:03:20 pm »
Changed the cam follower.
