Author Topic: What did you and your MKV do today?  (Read 4002987 times)
Offline Matto
  • -Receive: 116
« Reply #3630 on: February 18, 2013, 11:18:22 pm »
Cheers Matto. Can you post the link to your 'how to' VCDS post please?
Here you go mate http://www.mk5golfgti.co.uk/forum/index.php/topic,52526.html
« Last Edit: February 18, 2013, 11:24:20 pm by Matto »
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #3631 on: February 18, 2013, 11:27:54 pm »
Thank you Sir :happy2:
'07 Red manual
Offline scottm72
« Reply #3632 on: February 18, 2013, 11:33:42 pm »
if i am reading this right it looks like i have missed a mod,
are you saying you can code through vcds so that once you close the car doors and for example the windows are open you can lock the car with the normal one press of the key fob - but with this mod the windows will self close ?
can this be coded to all cars ?
cheers
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #3633 on: February 19, 2013, 12:18:22 am »
 :happy2:  yep   :happy2:
Silver is the way !
Offline scottm72
« Reply #3634 on: February 19, 2013, 01:07:42 am »
that's it man im buying a vcds unit,
got a few things i need to do now
Offline torque777
Re: Re: What did you and your MKV do today?
« Reply #3635 on: February 19, 2013, 06:28:20 am »
You can get folding option ...I didn't want it as I'm not retro fitting folding mirrors ...got them from bold-sport. Com
sent using my own fingers
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3636 on: February 19, 2013, 03:23:32 pm »
Changing the fuel filter today ;p
homesqueeze
« Reply #3637 on: February 19, 2013, 06:19:50 pm »
cheers
You can open and close the windows remotely as standard by just holding either the lock or unlock button down. The coding is only necessary if you want just a one press action.
Offline Polo6n1600i
« Reply #3638 on: February 20, 2013, 12:44:23 pm »
Coilovers, 312 brakes, timing belts & water pump, panel filter, oil chnage & filter, pollen filter, fuel filter.
A full days work tomorrow. Once its dropped and the tracking sorted I hope it handles better - pics up once its finished!
Offline Mikeygtir
« Reply #3639 on: February 20, 2013, 12:59:16 pm »
i installed and coded the boot pop mod.. cracking little mod that should have been OEM...
Offline Kalpsn2000
  • -Receive: 56
« Reply #3640 on: February 20, 2013, 02:18:22 pm »
Yes a great little mod. How's yours working? Mine usually doesn't work well in this cold weather, although I will be greasing up the ball joints this weekend to see if that helps.
Offline scottm72
« Reply #3641 on: February 20, 2013, 03:13:04 pm »
cheers
didnt even know i could raise the windows holding onto the key fob lol, works a treat, will code the one touch once i get vcds.
Noticed a glitch today, went into the newsagent for a few minutes and my window was open, came out and it was closed but it started to rain so obviouslly the self closing window function i got coded with vcds works - great - but - then noticed the intermittent wipers would not function apart from the first initial wipe ????
I tried it \ few times but didnt make a difference, the normal wiper function is ok but it seems to have affected the intermittent function regardless of speed set.
Will keep an eye on it as maybe it will sort itself as only happened today, if it does not fix itself that vcds option of the windows self closing when it is raining will be getting taken off,,,, anyone had this prob before ?
Offline Mikeygtir
« Reply #3642 on: February 20, 2013, 03:17:10 pm »
Mine is working grand today.. i sprayed some lithium grease on the cups of the ball joints and touch wood seems to be ok. its not that cold today so will have to try it on a frosty day for comparison
Offline Grande_GTi
  • -Given: 41
« Reply #3643 on: February 20, 2013, 03:56:33 pm »
I ordered 2 tyres
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline Mertyvw
« Reply #3644 on: February 20, 2013, 04:09:02 pm »
Got.
Air Filter , Fuel Filter, Pollen Cabin Filter. Oil Filter. 5w30 Castrol Edge Oil. Bosch Spark Glow Plugs, Oil Drainer. Oil Filter Wrench and not last but least the Boot pop modding parts :)
Black 5 Door TDI with BBS Pescaras, R32 Spoiler, Tints All Round. RCD510,CAN 7NO I aint touching the Engine> Im frightened of power :D
My sig pic is still to big.
