Author Topic: R style rear bumper  (Read 2416 times)
Offline derek
R style rear bumper
« on: June 28, 2011, 12:19:43 am »
did vw make a lower rear exhaust trim to fit the standard gti exhaust to fit the r32 style bumper? i have tried searching but cannot find what im looking for.
thanks
Re: R style rear bumper
« Reply #1 on: June 28, 2011, 12:54:32 am »
I'm 99% sure VW didn't (Mk5) but an aftermarket company has. In Germany I think - Sorry I don't have details.
Offline PND
  • -Receive: 62
« Reply #2 on: June 28, 2011, 07:35:44 am »
http://www.mk5golfgti.co.uk/forum/index.php/topic,31093.msg387344.html#msg387344
http://www.mk5golfgti.co.uk/forum/index.php/topic,28675.0.html
Not as good a fit as OEM items apparently..  and fibreglass rather than polyurethane I think..
Offline derek
« Reply #3 on: June 28, 2011, 08:42:28 am »
Thanks for your replies.
Has anyone bought from SRS-TEC before? Whats the qaulity of there items and the fitment like?
« Reply #4 on: June 28, 2011, 10:02:55 am »
I think the SRS-TEC is the one I was thinking about. Looks fine on their website and decent size pic viewable. I reckon much more reliable source than fleeBay which can be a matter of luck whether a product is good or rubbish unless you already know the trader.
A tip for you if you get one: The extreme right and left sides fixings may be a 'male' flat tab (my OSIR carbon exhaust trim is) and it can work loose. The trim won't fall off but it looks untidy being out of line. Drill a small hole big enough for a cable tie in each of the two side tabs - You'll have to cut and renew the cable ties if you ever want to remove the trim but that's eeeasy-peeasy.
^ Pic of underside but before I did the cable tie mod.
You can see there's plenty of places to tie and secure the trim - There's holes already there in the bodywork.
Offline derek
« Reply #5 on: June 28, 2011, 10:15:55 am »
Thanks for the heads up, think im just going to bite the bullet and buy it. Thats one way to find out  :confused:
dont know if you know or anyone else knows, Will it come the OEM plastic finish or will it need painting?
« Reply #6 on: June 28, 2011, 10:20:14 am »
....I would send them an email and ask. Also ask what material exactly and if they have any other pics of it when off a car so you can see the inside and thickness. I think you'll find that they'll be very helpful - German aftermarket companies usually are in my experience.
If you do get it or more info please post and share with us  :happy2:
jacko78
« Reply #7 on: June 28, 2011, 06:23:06 pm »
There's also a place on eBay called going fast which do the rear end your
After. Iirc it's about £150 and looks nice
Offline derek
« Reply #8 on: July 11, 2011, 11:52:27 am »
ok still on the subject of rear diffusers, i was following a mk6 yesterday and seen they have seperate diffusers/bumper.
Would anybody know if the rear diffuser would fit the mk5 R bumper? it doesnt look different from lookking at it.
Offline Weston
« Reply #9 on: July 11, 2011, 07:47:21 pm »
It definitely won't fit. The shape is similar but the R bumper insert is taller than the mk6 one.
GTI going...
