All Things Mk5 > How to Guides / Troubleshooting
Gti / Cupra / S3 rear brakes (removing discs)
<< < (2/3) > >>
Tfsi_Mike:
--- Quote from: vRStu on July 06, 2011, 08:34:58 pm ---I've done it several times and not had a huge issue.  Have you tried using a short extension on the ratchet?
Carl managed to do his last weekend so it can't be that hard  :signLOL:
--- End quote ---
I can fit the socket in.  There isnt enough room then for the ratchet, never mind an extension.   :sad1:
Tfsi_Mike:
Came accross this but doubt 10mm hex is upto the torque need to undo & re tighten???
vRStu:
Are you sure you're undoing the right bolts??
There should be two traditional M14 hex head bolts that hold the carrier in place.
Tfsi_Mike:
--- Quote from: vRStu on July 06, 2011, 09:11:08 pm ---Are you sure you're undoing the right bolts??
--- End quote ---
It looks like I am  :confused:  It's 2 M14 splined bolts holdin the Caliper on.  Need the caliper off to remove the disc
vRStu:
You surely had the caliper off when you did pads?  So all that is left is the carrier which is two M14 bolts.  Don't go trying to split the caliper.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
