General > Detailing
Paintwork Bumpy After Wax
Rob GTI:
--- Quote from: stealthwolf on July 12, 2011, 09:15:10 pm ---What conditions did you apply the wax in? What kind of applicator? How long did you leave it on? How did you buff off? How long after buffing did you have the problem?
Sounds like too much product. I'd use a quick detailer or even just water and a microfibre cloth.
Red Mist is more of a spray sealant and if applied too soon after waxing, will strip the wax rather than enhance it.
--- End quote ---
It says QD on the bottle though...
Yeah I'd read reports of red mist not to be applied directly after waxing , I remeber reading on DW tht you should leave wax to cure for 24-48hrs.
mdavis:
Thanks. Going on the replies I think its a mix of too much product and left for too long on the car. I will try the quick detailer or failing that, strip it back on the weekend and start again. Cheers
mdavis:
A spray with water and wiping it off did the job perfectly. Back to silky smooth. Thanks :drinking:
washwarehouse:
Hello mate,
As I am a Detailer myself I would say that the wax has been left on too long in the warm... TBH wax should only be applied in a cool environment pref indoors.
Also I am probably guessing that you have probably applied too much Wax and it has just been to much to buff off...
I would say wash the car heavily, plenty of shampoo in the buckets, and wash a few times with a lambs wool mitt. Dry the car off, and then have a go at re-waxing... You seriously do not have to use much wax at all. The thinner the layer the better.
Do the swipe test after around 15 mins or so (do try and do in the shade).......
This should be enough to re-lever the wax again...
After all the Wax is completely off (also use plenty of microfibres to wipe off the wax, they clog quick)... Leave the Car in the Sun to really bake on the wax that is left behind. (But do make sure you have buffed it all off before leaving in the sun!!!)
Job done
Navigation
[0] Message Index
[*] Previous page
Go to full version
