Author Topic: Tfsi Mikes Money Pit :: AKS built Cupra :: TTE420 :: Rtech Tuned  (Read 1052140 times)
Offline nickb
Re: Tfsi Mikes Money Pit :: Stage II+ Cupra **Mini Update 5th Oct
« Reply #225 on: October 05, 2011, 09:38:56 pm »
Last time they were together....  Snake Pass, Ladybower resevoir?
Be good to catch up dude.  Cabt wait to see the MkII again!  Tsr sent you any pics?
yeah mate think it was then! well the mk2s changed alot since then! nahh ive not asked for any pics, just been popping in every so often having a look.
heres a few pics of how it was last.... apologies for cluttering your thread..
« Reply #226 on: October 05, 2011, 09:42:47 pm »
 :party: :party:
 If your bothered about posting the beast on my thread (Im not bothered) you know what to do  :P
Post ya build thread, plenty of MkII owners & Fanbois on here + you're a potential Golf V owner  :wink:
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #227 on: October 06, 2011, 09:50:46 am »
I am a bit skeptical about the massive drop off as well hurdy, would like to see if it happens on further runs to eliminate dodgy readings as some of the other runs mike did had very odd data!  I did this one after the one mike posted about which does show that the boost pressure goes significantly above specified at the same time as the drop in mass air flow and this also co-insides with the start of the miss-fire on cylinder 3....  :confused:
« Reply #228 on: October 06, 2011, 12:39:44 pm »
The overboost is quite typical of the K04 engines on a remap. Mine used to do exactly the same, but didn't have the drop off in the MAF reading. The miss-fire on cylinder 3 could be anything and without further investigation is an unknown quantity. Usually the missfires are either a failing coilpack or improperly fitted/failing sparkplug. The drop in the MAF reading, coinciding with the missfire I'd take a stab at the MAF being faulty/partially blocked as the engine would try and compensate for the low MAF reading and alter the inputs to the engine for the fuel and air - this would show as an unusual reading on the Air fuel ratio reading on VCDS when you log it. - HTH :happy2:
« Reply #229 on: October 06, 2011, 05:51:15 pm »
Okay so I fitted the new revision PVC today...
Hasn't made any difference to the misfire but now when I remove the dipstick the engine now runs roughly.
« Reply #230 on: October 06, 2011, 08:12:15 pm »
Taking the MAF out at work Tomo to see if it's clean and undamaged.
Have an injector in the post but MAF wouldn't require labour costs....
Wonder if I could've killed the new plugs or coils driving it with the misfire?!  :scared:
Re: Tfsi Mikes Money Pit :: Stage II+ Cupra **misfiring still, thoughts?
« Reply #231 on: October 06, 2011, 11:15:19 pm »
Aha, has anyone looked at the possibility you may have a faulty N75 valve. I had mine replaced on the old ed30 for a similar fault. Plenty of threads on here for you to read to see if your car has similar symptoms.  :smiley:
« Reply #232 on: October 07, 2011, 06:02:33 am »
Did you have a misfire John?  :happy2:
« Reply #233 on: October 07, 2011, 12:27:37 pm »
Yes, I had a misfire AND uneven idle. Replaced the N75 valve and cured it. Not that expensive to replace either.
« Reply #234 on: October 07, 2011, 12:33:54 pm »
Although I'm against throwing money at diagnosing a fault before thorough investigated / logged.
Cheaper bits like n75 aren't so bad and if mine it's okay it will serve as a spare.
Thanks John  :happy2:
Offline graeme
« Reply #235 on: October 08, 2011, 04:45:52 pm »
i dont understand how the n75 valve causes a misfire at idle ... the ecu wouldnt even be asking for any boost so the turbo would be sitting below atmospheric pressure ? if the n75 was broken it would obviosly make the turbo impossible to controll giving the call full boost all the time ? no? im confused by this . . .
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #236 on: October 08, 2011, 05:00:10 pm »
his missfire isnt at idle you can see in the graph above it occurs just after maximum boost.
« Reply #237 on: October 08, 2011, 05:34:23 pm »
Initially basic measuring was counting a missfire at idle.
As it's got worse (when I logged it) it misses through the rev range
John suggested he had a rough idle and missfire so for the sake of €25 euros it won't hurt to renew the N75
« Reply #238 on: October 09, 2011, 02:42:50 pm »
Whipped MAF out to have alook.  Plug connections look fine no corrosion etc after all the jet washing.
However there was a fair bit of resudue on the body & inside the sensor itself
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #239 on: October 09, 2011, 08:19:02 pm »
What filter you running?
Took my airbox off yesterday to fit ITG filter and my maf was spotless...?
Diesel Daily Hack.
