Author Topic: 2 errors, any ideas?  (Read 5309 times)
Offline edd666999
  • -Receive: 89
« on: August 22, 2011, 10:49:09 am »
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003994074
   Coding: E58D0F2700041500001400001400000000087F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B5FACABF395
   Part No: 1K2 955 119 C
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 00000
   Part No: 1K0 955 559 T
   Component: RegenLichtSens 011  1110
   Coding: 00207646
   Shop #: WSC 00000
1 Fault Found:
00987 - Lamp for Brake Light; Left (M9)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 25
                    Reset counter: 61
                    Mileage: 81700 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.25 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 38 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD0A5D4Z
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3B7F9CEB03F5
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
I basically get a rear left brake light out error intermittantly and replacing the bulb doesn't help.
And I also get thr air bag light on, clearing the error make it go away for a week or 2.
Re: 2 errors, any ideas?
« Reply #1 on: August 22, 2011, 11:57:37 am »
The airbag one will be the wiring under the seat. Fairly common fault and should be done under warranty if applicable.
As for the the brake light, fook knows, torch it.  :laugh:
Offline edd666999
  • -Receive: 89
« Reply #2 on: August 22, 2011, 12:00:47 pm »
No warranty left so what do I need to buy n replace?
Offline bacillus
  • -Receive: 453
« Reply #3 on: August 22, 2011, 12:59:10 pm »
Is that looter talk??   :laugh:
« Reply #4 on: August 22, 2011, 01:51:21 pm »
I'm afraid unless someone knows better it's a dealer job.
 :signLOL:
Offline edd666999
  • -Receive: 89
« Reply #5 on: July 04, 2012, 06:23:51 pm »
So to bring this back to life! my airbag light now doesnt go out even after resetting it with vcds.
I have done this fix listed here:
http://forums.vwvortex.com/showthread.php?2815467
on my passenger seat. but still not resolved the issue? any ideas?
Offline edd666999
  • -Receive: 89
« Reply #6 on: July 14, 2012, 02:12:30 am »
no one?
Offline skard
  • -Receive: 245
« Reply #7 on: July 14, 2012, 02:29:31 am »
Same fault on the same side?
Did the light go out after performing the work in the bulletin? Is there any possibility your work could have become undone?
Check the airbag plug from the seat to loom under the black plastic cap - see if the pins all line up and don't suffer from any sort of corrosion.
Offline edd666999
  • -Receive: 89
« Reply #8 on: July 23, 2012, 07:19:50 am »
didnt notice your reply.
same side yes passenger seat, plugs have been disconnected and checked! Its a MOT fail too and its in for a MOT at the moment...not sure where im going to go from here...
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #9 on: July 23, 2012, 08:39:35 am »
My last Octavia had this and had to have the igniter replaced! Luckily I had a warranty as its about £600 to fix iirc :scared:
Offline edd666999
  • -Receive: 89
« Reply #10 on: July 23, 2012, 08:49:40 am »
this is what i was afraid of. I will just buy a new interior if this is the case.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #11 on: July 23, 2012, 08:51:48 am »
But that won't include an airbag igniter though will it?
Offline titchy
« Reply #12 on: July 23, 2012, 09:05:39 am »
try a site http/:wwwbbareman thheres a guy on there called crasher bit of a genius on VAG. give as much info as pos.  incthe stuff you put on here. you have to register but its free hope this helps
Offline edd666999
  • -Receive: 89
« Reply #13 on: July 23, 2012, 07:49:00 pm »
oh, i assumed its all inside the chair...
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #14 on: July 23, 2012, 08:58:14 pm »
Ignore me. I was thinking you were talking headlinings etc :grin:
