All Things Mk5 > Mk5 General Area
disappointing performance continued....UPDATED after a day at MRC Tuning
duncan:
--- Quote from: Steve Baker on April 03, 2009, 05:00:16 pm ---The easiest way to discount an ECU fault would be to substitute the ECU with known good from another vehicle and data log accordingly. If the excess fuel situation still exists then there is clearly a fundamental underlying problem that really needs sorting before altering the map? :wink:
--- End quote ---
agreed!!!
and would have liked to have done that, but the having an ECU to swap would be the first mission, then the labour charge for swapping and diagnostics would cost me at least a few hundred and since the car is still under warranty am pretty reluctant to spend money on it.
getting the remap made sense in a way although it didnt diagnose the full problem, it was at least 2 hours of free diagnostics that ruled out alot of problems that the car could have had which in turn made the remap much cheaper since i got all that labor for free!
also the way i see it if this could be the start of a problem that would need fixing it would become obvious enough for VW to fix the car under warranty
Phil Mcavity:
Rolling road day coming up Duncan, bring it down mate and have a look.
http://www.mk5golfgti.co.uk/forum/index.php?topic=2883.0
duncan:
--- Quote from: Phil Mcavity on April 03, 2009, 07:13:09 pm ---Rooling road day coming up Duncan, bring it down mate and have a look.
--- End quote ---
looks good - not a million miles away from portsmouth. just need to check if im working that weekend, got a feeling im off so would be good to make it down there.
although I almost dont want to put the car on the rollers becuase if its still only putting out 220bhp ill be so pissed off lol
Phil Mcavity:
add your name to the thread list if you can make it Duncan ok.
duncan:
--- Quote from: Phil Mcavity on April 03, 2009, 08:20:03 pm ---add your name to the thread list if you can make it Duncan ok.
--- End quote ---
will do - should know by tuesday
Navigation
[0] Message Index
[*] Previous page
Go to full version
