Author Topic: Can anyone close to their Edition 30 do me a favour please!  (Read 10815 times)
Offline heavyd
  • -Receive: 29
« on: September 20, 2011, 10:09:22 am »
I'm in a bit of a wrangle with the local vw dealer at the minute.
I was just wondering if anyone could do me a favour please and start their engine and take the dipstick out and see if theres a vacuum please?
I'm sure theres supposed to be due to the pcv system, but they saying there isnt, and something is broken in the bottom end :confused:
Thanks in advance for anyone willing to help :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bsvscutkk78v5g4rfreo44hvv2&/topic,19740.0.html
Re: Can anyone close to their Edition 30 do me a favour please!
« Reply #1 on: September 20, 2011, 10:25:52 am »
When you remove the dipstick the tone of the engine changes, if it doesn't change the PCV is shot.
Offline heavyd
  • -Receive: 29
« Reply #2 on: September 20, 2011, 10:51:28 am »
I fully understand that, what they are saying is, is that theres too much pressure in the bottom end of the engine, and there is a vacuum when the dipstick is removed which can be felt when you put your hand over the dipstick pipe. I'm sure that this is down to the vacuum created by the PCV system, but they said they tried it on another GTi, and there was no vacuum.
My argument is that they charged me £1370 for a turbo that they said I needed fitting, when the car still has the same issues afterwards, so I didnt even need that turbo fitting, and I'm trying to find out what the problem is
« Reply #3 on: September 20, 2011, 10:58:40 am »
Ill check in a bit, unless someone beats me to it  :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #4 on: September 20, 2011, 10:59:19 am »
I know if you take the oil cap off there's a vacumn on mine, and if you pull the cap off the engine doesn't like it... not sure bout dipstick
Diesel Daily Hack.
« Reply #5 on: September 20, 2011, 11:43:40 am »
Yes there is a vacuum via the dipstick tube.  :happy2:
Offline heavyd
  • -Receive: 29
« Reply #6 on: September 20, 2011, 12:38:37 pm »
Thanks richwig :happy2: much appreciated.
Back to the dealers it is then :fighting:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #7 on: September 20, 2011, 12:42:03 pm »
If I were you I'd go to another dealer.  Wouldn't trust them with a wheel barrow going by what you've said so far.
Sepang Blue S4 BE Avant
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #8 on: September 20, 2011, 12:45:23 pm »
Speak with Tariq at VW customer services also...
Diesel Daily Hack.
Offline heavyd
  • -Receive: 29
« Reply #9 on: September 21, 2011, 03:41:04 pm »
Went back to the dealers, and I'm sorry to inform you that there must be something wrong with you car aswell Richwig I was told today there definetly shouldnt be any vaccuum at the dipstick :laugh: :laugh:
Back in for a full day again a week monday to sort the vaccuum in the dipstick tube :stupid:
Offline johnboy07
« Reply #10 on: September 21, 2011, 03:44:00 pm »
i have no idea if it should or shouldnt vacuum but on mine with the dipstick or the filler cap is removed mine does not change at all. i have a pcv revamp kit from bsh so nothing to do with that, how weird  :sad1:
Stage 2+ 280.4 bhp ITG, Revo Stage 2+, decat, hpfp, THS intercooler, THS engine mounts, Pcv revamp, sportline springs, rs4 fuel valve, DS2500 pads and brembo discs, braided lines, ATE super blue brake fluid and more to come
« Reply #11 on: September 21, 2011, 04:03:42 pm »
I'm lead to believe that the engine tone should change when you remove the dipstick. It runs funny like it's misfiring, if you put your finger over the dipstick tube the idle returns to normal. There is defo a vacuum there mate. *confused.com*
.:Tapatalk:.
Offline PDT
  • -Receive: 142
« Reply #12 on: September 21, 2011, 04:13:48 pm »
Dom, use another dealers. Had a car in today  (mk4 golf 1.9) that had been to them for 3 DAYS to diagnose a boost fault (would cut out all boost under load at 3600 rpm)
Did a quick run up the road to datalog and at the split second before it hit 2000mb the map sensor signal would go flat and then immediately into limp mode. Removed map sensor from the intake pipe and connected it to my hand pump and watched the live data from OBD port, gave it 2500mb and same happened, would only read 1980mb.
£12 later and a new map sensor = fixed.
Dealer had spent 3 days with it and diagnosed a new turbo was required, fitted cost £1240  :signLOL: thats an oversight of around 1000%. they had charged him £240 for this diagnosis, he is going back to them to attempt a refund.
« Reply #13 on: September 21, 2011, 04:16:25 pm »
^^^ LOL!!!
So a vacuum at the dipstick is correct?
.:Tapatalk:.
Offline PDT
  • -Receive: 142
