Author Topic: Anyone know how to wire up Headlamp washers?  (Read 2554 times)
Offline Shammyy786
« on: December 03, 2011, 11:02:07 pm »
The easy part of the headlamp washers is connecting the wires through the water pump however im a little confused when it comes to wiring it up electrical wise, what do I need to carry out or do I just vag-com it as apparently the washers function through the wipers.
Also has anyone got any pictures I could see of how the washers are wired up for the water to go through and a shot of the washer bottle with where all the wires lead as I am a little confused,
Thanks guys
EDIT: My vehicle is a 2005 05 Golf V 1.4 S with a GTi front bumper conversion so im guessing washer wiring will be different to the standard but the electrics be the same?
« Last Edit: December 03, 2011, 11:06:38 pm by Shammyy786 »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bqqankm8mfda465ki6bkjiqt43&/topic,19740.0.html
Re: Anyone know how to wire up Headlamp washers?
« Reply #1 on: December 03, 2011, 11:14:04 pm »
alexperkins has done this recently!  :happy2:
Offline Shammyy786
« Reply #2 on: December 03, 2011, 11:16:31 pm »
Yeah I remember speaking to him through another post but cant contact him as he hasnt left his email, also he gave me a link to the washer system but its the electric wiring im wondering about how to do and where to connect
Offline skard
  • -Receive: 245
« Reply #3 on: December 04, 2011, 12:12:45 am »
I've done this.
When you get the kufatec loom it comes with instructions. There's connections to be made to CECM, fuse box internal and instrument cluster.
Offline daveangel
« Reply #4 on: December 04, 2011, 10:51:04 am »
Manual wiring SRA VW Golf V/ Touran
Please disconnect the battery before starting installation.
Please wire the loom to the following connections:
Wire configuration:
- Remove the battery as well as the cover behind
- Wiring through the tull behind the battery towards the footwell
- Wire the loom in the engine compartment towards the head light on the right hand side to the
tank
- Place the relay above the control unit for central electric
- Red/ White loom to PIN 8 of the relay socket
- Yellow loom to the control unit for central electric – connector D – PIN 8
- Mount the relais socket again
- Black/ Yellow – Fuse box
- Brown – Ground
- Violett (Water) – 35-pole connector of the instrument cluster PIN 34
– For A3 8P 32-pole connector PIN 20
