All Things Mk5 > How to Guides / Troubleshooting
Door & Dashboard Alumium Trim Strips....
<< < (6/6)
v2brett:
--- Quote from: RedRobin on April 16, 2009, 11:18:36 pm ---
--- Quote from: v2brett on April 16, 2009, 11:03:03 pm ---
they come off quite easy but can also bend easily, i had mine off a while back to find a rattle.   dont worry if they bend though they straighten back.  and i think it would be hard to lose any clips  :happy2:  all the clips seem lose without the strips though
--- End quote ---
....So you can pull them off without removing any door cards etc?
Any tool which is best to use as a lever?
Start in the middle? End?
[You can tell how good I am at such things!]
--- End quote ---
i started at the ends and the door card def stays on, and as above the best things are those plastic trim remover thingys  :happy2:
SeanyK:
My driver side aluminium door trim has developed a rather irritating rattle lol - so will be removing and putting a bit of double sided tape behind it to stop that!
RedRobin:
--- Quote from: SeanyK on July 28, 2010, 02:10:53 pm ---
--- End quote ---
....Be careful not to break any more of the rather fragile plastic fixings when removing/refixing. These strips aren't really designed to be taken on and off by VW's customers!
Saint Steve:
--- Quote from: RedRobin on July 28, 2010, 02:41:28 pm ---
--- End quote ---
Especially carefull ahe Mr Hedge  :wink:
--- End quote ---
SeanyK:
I suspect the previous owner broke one of the clips, hence why it makes a noise unless I press it in!
It's not that loud, just irritating, 9 times out of 10 the stereo will drown out any rattles, after all, I am in Essex  :evilgrin:
Navigation
[0] Message Index
[*] Previous page
Go to full version
