Author Topic: Data logging results - Bit concerned  (Read 4189 times)
  • -Receive: 453
Re: Data logging results - Bit concerned
« Reply #15 on: December 23, 2011, 10:54:17 am »
What year is your car as if it's an early model then removing the hpfp may prove a little difficult/fiddley if you have a banjo bolt pump attachment.
Offline ktlstar
« Reply #16 on: December 23, 2011, 11:00:09 am »
57 plate dude.
It's ok, I went out and remove  the pump and to check the follower (So i know what im pretty much doing tomorrow*install hpfp*). Took me 30minutes. The only pain was trying to move the hose clamp to the front  as it was sitting near at the back of the pump.
 :driver: I hope after installing it, it will be all good with the revo settings it has. Will update and maybe you guys can clarify for me if all good  :santa:
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline ktlstar
« Reply #17 on: December 24, 2011, 12:07:54 pm »
Fitted the fuel internals early this morning, then did a few quick runs. I forgot to log the RPM however at 130bar of pressure you know im at full WOT.
Heres a 2 logs / chart. I am still concerned seeing -0.8. I thought -0.5 is max you want ????? As you can the pump is holding up with the requsted fuel.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=kvfc3i4m3k2flam05980je6mvd&/topic,19740.0.html
« Reply #18 on: December 24, 2011, 01:11:55 pm »
-0.8 timing pull is low. When first mapped mine was reading about -6 at high revs, dodgy cheap fuel.
Offline ktlstar
« Reply #19 on: December 24, 2011, 01:18:40 pm »
Cheers Rich, im using new oem plugs, 99 fuel.   All seems good then to boost and enjoy ?
  • -Receive: 453
« Reply #20 on: December 24, 2011, 01:47:48 pm »
Up to -5.0 CF is acceptable but closer to zero is better.   :smiley:
Offline ktlstar
« Reply #21 on: December 24, 2011, 02:50:56 pm »
Car seems slower then before. Looking at the air mass its got lower readings then before. Any ideas ?
Before seeing 250-260 and now highest is 230
« Last Edit: December 24, 2011, 02:53:07 pm by ktlstar »
