Author Topic: Need some help with accelerator pedal  (Read 2408 times)
Offline Yawn
« on: December 27, 2011, 03:26:01 pm »
Help!
I tried to fit my new accelerator pedal today, got it free of the floor ok but the electrical connector was proving awkward to disconnect and now the little grey 'clip' has broken off.
Any ideas would be great!
Thanks!
Offline vRSAlex
  • -Receive: 253
Re: Need some help with accelerator pedal
« Reply #1 on: December 27, 2011, 03:35:37 pm »
Is the connector still on or did you manage to get it off?  If the clip breaks then get a little pick in behind it to release the tab that holds the connector to the pedal.
Have you got any pics of the bit that's broken off?
Follow AKS tuning on Facebook
Offline Yawn
« Reply #2 on: December 27, 2011, 03:59:31 pm »
Thanks for replying,
I don't have a picture but its the 'moveable' bit a bit like a button? and no I didn't get the connector off. I left whilst I cooled off and cursed my ineptitude.
Not sure what you mean by a 'pick'?
Thanks!
I've found this http://jettagolf.blogspot.com/2009/04/how-to-replace-gas-pedal.html
So I'm going to try taking the side piece off next.
« Last Edit: December 27, 2011, 06:24:27 pm by Yawn »
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: December 27, 2011, 07:49:44 pm »
Step number four in the link sort of explains how to get the plug off if it breaks.  This is the pick I use (2nd in from the left):
Offline Yawn
« Reply #4 on: December 27, 2011, 08:17:42 pm »
Thanks again,
I don't have a pick but I might have something similar.
Cheers!
Offline Marshall
Re: Re: Need some help with accelerator pedal
« Reply #5 on: December 27, 2011, 08:35:13 pm »
As above if you can get a small screwdriver or something behind the lug it will slide off.
Don't break the lug off or it won't secure back on properly. Best with a torch and some patience.
Sent from my HTC Sensation XE
MISANO RED RS3
Offline Yawn
« Reply #6 on: December 28, 2011, 03:52:32 pm »
Righto! thannks, I'll give it a go!
Offline Yawn
« Reply #7 on: December 30, 2011, 10:52:19 am »
WooHoo!
Done it.
If you are going to have a go, remove the side piece of the pedal before trying to remove the plug. It makes it so much easier.
Thanks chaps.
Offline Marshall
« Reply #8 on: December 31, 2011, 05:23:08 pm »
Glad you managed ok.
They're easy when you know how its just the first time. :confused:
MISANO RED RS3
