All Things Mk5 > Performance Modifications
K03 Stage 3 question
vRSAlex:
The main improvement with dumping the oem airbox is a slight gain in boost throughout the rev range and the turbo doesn't have to work as hard.
martziniuk:
I just run with an OE panel filter at stage 2+, there isn't much difference in performance as I rarely go high rpm.
bacillus:
--- Quote from: martziniuk on January 23, 2012, 12:53:24 pm ---I just run with an OE panel filter at stage 2+, there isn't much difference in performance as I rarely go high rpm.
--- End quote ---
You'll see how good the k03 actually is in the low rpm range once you go k04... :smiley:
james:
--- Quote from: bacillus on January 23, 2012, 01:23:33 pm ---
--- End quote ---
--- End quote ---
na my k04 is far better at low rpm to the k03.
martziniuk:
--- End quote ---
--- End quote ---
I would expect to see spool up time take a little longer with the k04 as its a larger turbo but hopefully no too long :driver:
Navigation
[0] Message Index
[*] Previous page
Go to full version
