Author Topic: 4 wheel alignment  (Read 6231 times)
Offline Russ_leeds
4 wheel alignment
« on: February 18, 2012, 12:47:08 pm »
Hi, I recently had 35mm h&r springs, front and rear arbs and walk fitted, after which I had a four wheel alignment done. If my steering wheel is straight my car pulls to the right so i have to drive slightly turned to the left. Im going back on thursday, but can anyone tell me how these results look please.
Front
camber left -1.26
camber right -0.36
caster left +08.08
caster right +08.52
Toe left -00.01
toe right +00.01
Rear
Camber left -01.48
camber right -01.50
toe left +00.16
toe right +00.14
Any help would be much appreciated  :drinking:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline jimk04
Re: 4 wheel alignment
« Reply #1 on: February 18, 2012, 01:01:05 pm »
Right front camber needs increasing :happy2:
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline Russ_leeds
« Reply #2 on: February 18, 2012, 01:09:46 pm »
they said camber is not adjustable? i thought that was a big difference though
Offline jimk04
« Reply #3 on: February 18, 2012, 01:30:51 pm »
There is a little movement in the 3 fixings on the top mounts.
Offline Russ_leeds
« Reply #4 on: February 18, 2012, 01:35:10 pm »
cheers mate ill get them to have a look when i go back down
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #5 on: February 18, 2012, 04:24:44 pm »
Front
camber left -1.26
camber right -0.36
 :scared: A huge difference !! Both should have to be within +-10'.
Did you car have an accident? Possibly one or two struts are bent.
caster left +08.08
caster right +08.52
Not perfect. Same problem as above.
Toe left -00.01
toe right +00.01
Total +0°10' (5' + 5') recommended by Volkswagen. No problem to adjust.
Rear
Camber left -01.48
camber right -01.50
Almost perfect! I'd go for -1°30' though.
toe left +00.16
toe right +00.14
VW rec.: +10' total as on front. So a bit too much. This may cause some humming
with some tyrers (esp. Dunlop and Bridgestone).
"You get what you pay for."
Offline Russ_leeds
« Reply #6 on: February 18, 2012, 06:04:09 pm »
No car has not had an accident just had all the mods fitted. ive owned it for just over 2 years and one previous lady owner before me hpi clear
so what values would you expect to see when right?
cheers
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #7 on: February 18, 2012, 09:29:23 pm »
I already told you the values. (degrees + minutes)
The total amount of camber on front is not adjustable.
You just have to keep both sides equal.
But this huge difference will be hard to center even when
shifting the subframe.
Offline mkviken
« Reply #8 on: February 18, 2012, 10:30:38 pm »
here are my numbers
my car has WALK and bump steer kit. castor will be slightly high cos of walk but otherwise these numbers are a good range to shoot for. my car was about 1000miles old when i got this done and my rear toe was slightly out from the factory.
Offline Russ_leeds
« Reply #9 on: February 19, 2012, 12:19:00 am »
thanks ill get it looked at by a garage make sure everythings ok with the struts.
Anyone know of a decent place to get another 4 wheel alignment done in or around leeds?
cheers
Offline Russ_leeds
« Reply #10 on: February 19, 2012, 05:49:32 pm »
or the best place to go who know their way round a gti?
cheers
Offline Russ_leeds
« Reply #11 on: February 20, 2012, 02:26:06 pm »
Anyone?
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #12 on: February 20, 2012, 03:03:37 pm »
Might be worth ringing RS Tuning and seeing if they do it, or can recommend someone. I'd be interested if you find somewhere.
Offline Turbosteve
« Reply #13 on: February 20, 2012, 03:13:29 pm »
Anyone?
I have been looking for ages..... found someone who does it the old way but not the computer way......
ATB
Steve
Offline Deacon
« Reply #14 on: February 20, 2012, 03:45:58 pm »
Chris Franklin at centre gravity in the midlands is a genius when it comes to setting up geometry. They're always very busy though - you'd probably be booking for end of April or so.
The set up he did on my scirocco is one of the best mods I've done - actually drives as it should!
