Author Topic: Geometry are my settings ok?  (Read 3889 times)
Offline neil86
« on: March 12, 2012, 08:33:54 pm »
As in title do these figures seem ok it drives fine bar the wheel bearing noises am getting since lowering it.
Offline mkviken
Re: Geometry are my settings ok?
« Reply #1 on: March 12, 2012, 09:45:11 pm »
looks spot on. thrust angle is good, toe spot on and caster spot on
my front camber is 0'54 though so different to yours but its green and mine is a mk6. rear camber is same as yours
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: March 12, 2012, 09:47:52 pm »
Perfect settings on a lowered car.  :happy2:
Follow AKS tuning on Facebook
Offline tony_danza
  • -Receive: 112
« Reply #3 on: March 12, 2012, 09:49:27 pm »
Get rid of that rear camber and toe in, it'll handle much better. 1/2 degree less than the front and set straight ahead.
Sideways yo!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=sqlavam1nptdg36b45h3naq5l7&/topic,19740.0.html
« Reply #4 on: March 12, 2012, 09:51:21 pm »
Still need to get mine adjusted, been meaning to do it for 6 months  :signLOL:
Offline tony_danza
  • -Receive: 112
« Reply #5 on: March 12, 2012, 10:06:34 pm »
Loose is fast, and rubbin's racin'. It's why French cars do this  :happy2:
Sideways yo!
« Reply #6 on: March 12, 2012, 10:10:28 pm »
Weeeeeeeeeeeeee  :driver:
Offline neil86
« Reply #7 on: March 12, 2012, 10:27:42 pm »
Could you give me an idea of numbers on the rear and front that you think should be different mate?
Offline tony_danza
  • -Receive: 112
« Reply #8 on: March 12, 2012, 10:31:44 pm »
You can't change the front caster/camber geo without hardware, WALK and/or wishbones/topmounts. The toe in is fine for road use.
Take the rear camber down to .50degrees and zero toe.
Sideways yo!
Offline neil86
« Reply #9 on: March 12, 2012, 10:55:12 pm »
Could the camber and toe on rear be creating bearing sounds within the car? If I take it down to 0.50 won't that be less than the front by half as you said earlier, I just thought you always wanted more on the rear I did asK this at the time of alignment? Cheers
« Reply #10 on: March 12, 2012, 11:04:23 pm »
Have you checked your tyres (especially the rear tyres, inside edge) for uneven wear? That's the most common reason for a bearing type noise.
Offline tony_danza
  • -Receive: 112
« Reply #11 on: March 12, 2012, 11:06:27 pm »
The bearing sound could be your tyres flat spotting due to bad geo, they turn into 50ps and drone.
Yeah, I've suggested knocking a full degree out, but 1/2 minimum. More rear camber is safer, as it gives the rear more lateral grip and ensures understeer is your first point of call... this however makes for a very boring car. Early GTIs had no rear grip, which is why the press loved them and you see loads of shots of them in massive lift-off oversteer slides. They soon changed it when the fecking 'we'll sue for anything' Yanks started sticking them on their roof.
Sideways yo!
Offline neil86
« Reply #12 on: March 13, 2012, 08:03:39 am »
Argh so my settings are ok for standard to modified set up just a safe setup rather than a oversteer twitchy setup I understand now what you mean. Less camber will loosen the rear end. Will have a look at my tyres didn't do it till I dropped the car lol
Offline the bruce
  • -Given: 322
  • -Receive: 101
    • my GTI
« Reply #13 on: March 13, 2012, 08:40:38 am »
 :congrats:
Looks fine !!
If you don't track it and like it that way leave it as it is.
"You get what you pay for."
Offline neil86
« Reply #14 on: March 13, 2012, 09:44:46 am »
Oh I don't track it would like to but fixing all my issues is costing me enough never mind tracking it and breaking it ha ha
