Author Topic: Front badge - split and carbon wrapped.  (Read 11020 times)
Offline tony_danza
  • -Receive: 112
Re: Front badge - splitting and carbon wrapping *WIP.
« Reply #15 on: May 07, 2009, 05:09:23 pm »
Cheers,
Nah - the pressed plates just try pulling straight all the time on the sticky fixings, so look a bit off. I'll sort it when I can lay my hands on some really strong stuff.
Sideways yo!
Offline true-blue
« Reply #16 on: May 07, 2009, 10:01:54 pm »
Simple, but very effective, I like that a lot  :happy2:
Octavia Vrs MKII - KO4, forge twintercooler, S3 Injectors, APR HPFP, RS4 FP Valve, Pipeworx 3'' DP and Sports cat, Piper non res exhuast, ITG Maxogen, Quaife Dif, sachs clutch kit, NQSBBBK with RS4-2 pads, H&R SS Coilovers with adjustable koni inserts.
Good for 328 BHP on JKM's rollers !!
Phil Mcavity
« Reply #17 on: May 07, 2009, 10:08:45 pm »
Tony, after seeing and not realising that the chrome badge seperates, i removed my 1st effort of wrap, and redone it the same way as you, and it looks FAR better.  :drinking:
Offline vwrascal
« Reply #18 on: May 07, 2009, 10:53:13 pm »
looks great that   :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #19 on: May 08, 2009, 09:09:52 am »
:smiley: Not sure I'd have been happy myself doing it any other way.
It's a doddle once you've got past the screwing up your face "Ooooo" stage of forcing the first tab, begging it not to snap the badge!! I reckon I could turn one around inside an hour from grille off to back on now.
Massive thanks to RedRobin for sending me an offcut to play with  :happy2:
I've had a look on ebay and there's some squares of it on there for a couple of quid, you want something about 200mmx200mm, as you'll need some excess to help you manipulate the material.
Here's how I did it, no doubt someone else can add to it and refine.
  • Remove the vinyl backing and lay down sticky side up.
  • Lay the badge gently onto the vinyl and let the centre catch.
  • Pick it up with the badge and working from the centre, smooth the vinyl onto the 'VW'.
  • Once the face is done, you need to manipulate the edging.
  • Using a pulling and stretching motion with the excess, work around the badge doing a little at a time. Stretch the material and work it with your thumb to ensure it doesn't crease.
  • Wrap this around the back of the badge and then trim off any excess - you're then at the stage to cut.
  • Using a very sharp craft knife, cut the line that runs at the bottom of the V and the top/middle of the W. Go straight down the middle, as you'll need this small amount to wrap back onto itself to cover the chrome.
  • With the rest of the cutouts, do an X staying about 1mm away from the corners. Pull the triangles back around the sections and smooth into the corners with the back of your knife to get a good edge/seal all round. You may need to carefully trim the centre cut you made between the V&W to ensure any overlap doesn't look scruffy.
Sideways yo!
« Reply #20 on: May 08, 2009, 09:11:58 am »
so when are you posting me mine?  :chicken:
:grin:
Re: Front badge - split and carbon wrapped.
« Reply #21 on: May 08, 2009, 09:14:50 am »
thats a great job mike, and thanks for the how to up there! might try this myself! :)
« Reply #22 on: May 08, 2009, 09:29:38 am »
That looks brilliant matey, shame I dont have a MKV to try it on  :sad:
Offline tony_danza
  • -Receive: 112
« Reply #23 on: May 08, 2009, 09:40:30 am »
VC/JPC - just do it, it's a couple of quid in vinyl and a couple of hours of your time - you can always take it off and try again if it's not right first time.
Sideways yo!
Offline jt1
« Reply #24 on: May 08, 2009, 11:04:54 am »
Excellent job matey, gonna order some vinyl of ebay and have a go at this :happy2:
Nice one :wink: :wink:
Offline Caz
  • Golf GT Sport TDi - called Gordon
« Reply #25 on: May 08, 2009, 11:57:51 am »
:grin:
2nd did..  :grin:
".. in the process of learning the vw service trade!"
Ifti
« Reply #26 on: May 08, 2009, 12:41:10 pm »
I may take a go at this - any links to the vinyl on eBay?
Also - does it come off cleanly if you mess it up??
How strong is it - I mean will it wear with weather etc?
Offline tony_danza
  • -Receive: 112
« Reply #27 on: May 08, 2009, 12:48:08 pm »
I dunno, RR sent me a sample from his - so I guess he'd be the best person to ask for the actual make/type.
Any external vinyl should be good for 5 years, apparently. Just ensure you get the good, thick stuff with a textured weave - not something with a print of it.
My experience of removing vinyl stickers, they come off very easily and at most just need a wipe with something to cut through any small residue, like glass cleaner.
« Last Edit: May 08, 2009, 12:53:19 pm by tony_danza »
Sideways yo!
Offline CocoPops
    • Kennet Heath
« Reply #28 on: May 08, 2009, 01:02:04 pm »
Interesting....
Just spoke to the supplier of the Vinyl...
£305+VAT buys you a 10m roll of 150cm wide CF vinyl.
Just think how many badges you could do with that!!
They do sell a 75cm wide roll in lengths of 5,10,25,50m
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
« Reply #29 on: May 08, 2009, 03:38:50 pm »
so what your saying is someone needs to buy a roll and then sell it off to members in sections?  :innocent:
(...and no i'm not putting myself forward either  :grin:)
