Author Topic: Is it safe to drive car after fitting S3 Injectors without remap  (Read 6661 times)
Offline Sammy
I have the S3 injectors on atm and booked in for remap by r tech 4 weeks later, What I want to know is anything being damaged or is there risks if the car is driven for the time being? I really need my car 7 days a week so this is a big issue to me
GTI MK5 with all the gooodies
K04 power going on soon!
Offline ktlstar
Re: Is it safe to drive car after fitting S3 Injectors without remap
« Reply #1 on: May 18, 2012, 12:24:11 am »
ull notice alot more fuel usage, but i wouldnt drive it hard untill its mapped properly.
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline bacillus
  • -Receive: 453
« Reply #2 on: May 18, 2012, 04:11:59 pm »
Technically you can drive it but keep the engine off boost as much as you can...
Offline Sammy
« Reply #3 on: May 18, 2012, 04:24:24 pm »
What are the dangers of driving with boost wtho map anyone know? I cant see much issue other then overfuelling? Can pistons or anything else get blown? I do have a 4 week wait whch is very long so need to know before my engine or something blows up!
Offline bacillus
  • -Receive: 453
« Reply #4 on: May 18, 2012, 04:41:37 pm »
Without the correct mapping you will over boost and more than likely end up in limp mode.
Offline Sammy
« Reply #5 on: May 18, 2012, 04:50:17 pm »
Yeah i do go in to limp mode every now and then when flooring it to redline but then if i switch off the engine and start it again it goes back to normal, What components of the engine are at risk when overboosting or overfuelling?
Offline bacillus
  • -Receive: 453
« Reply #6 on: May 18, 2012, 05:02:24 pm »
Too much boost can bend your rods.   :evilgrin:
Offline Sammy
« Reply #7 on: May 18, 2012, 05:06:41 pm »
Oh damnn am i overboosting i dont know overfuelling i think so, crap this 4 week sounds more scary then I thought
Offline james
« Reply #8 on: May 18, 2012, 08:42:06 pm »
oh is ur engine a BWA or AXX?
« Reply #9 on: May 18, 2012, 08:49:35 pm »
....Tut tut tut, that's not clever!
Who did the conversion? They should have done the appropriate remap at the same time or at the very least have warned you to take it very easy meantime. You should be patient and granny it or it could cost you a lot more.
Offline Sammy
« Reply #10 on: May 18, 2012, 11:17:51 pm »
My engine is AXX james why?
The conversion was done at a local garage to me and they dont do maps at all but did not give any driving advice either but did ask if I am going to get it mapped, Gna have to really have a boring gt for the next few weeks argh!
Offline james
« Reply #11 on: May 19, 2012, 12:01:21 am »
be intrested to see what you get with an axx,  keep an eye on your weak cam mate  :drinking:
Offline Sammy
« Reply #12 on: May 19, 2012, 12:05:42 am »
Eye on weak cam while not mapped or do you mean the AXX engine as overall having weak cams?
Offline james
« Reply #13 on: May 19, 2012, 12:22:10 am »
they just have weak cams in general
Offline vRSAlex
  • -Receive: 253
« Reply #14 on: May 19, 2012, 07:14:54 am »
The early AXX had the 'A' version of the inlet cam which had a soft fuel pump lobe.  My understanding was that all the cars fitted with the 'A' cam had them swapped out for the 'B' version.
Follow AKS tuning on Facebook
