All Things Mk5 > Performance Modifications
Stage 1 Re-Map, should I buy and fit a filter first?
<< < (5/5)
gigolo456:
I have just spoken with an Independent VAG specialist in Doncaster, and he suggested that if i do go for a Stage 1.5 with R-Tech (same as usual Stage 2 with others), and if i have a new HPFP fitted, it could lead to further problems down the line, eg with the cam-follower! However he did suggest that i have a new 'bucket' fitted, although i didn't quite grasp what this actually is, any ideas folks??
Andrew
56OctyVRS:
Its called a cam follower .  If you click the link it willshow you how to and what one looks like :happy2:
http://www.briskoda.net/forums/topic/142836-how-to-change-fuel-pump-cam-follower-on-2-0-tfsi/
gigolo456:
ahhh, are you suggesting that the cam-follower and 'bucket' are one and the same??
56OctyVRS:
The follower is bucket shaped.
gigolo456:
Cheers, any ideas y he mite want 2 change only that and keep the standard fuel pump??
Navigation
[0] Message Index
[*] Previous page
Go to full version
