Author Topic: Oil pressure warning light switch off engine!  (Read 22401 times)
Offline Sammy
« on: June 17, 2012, 01:23:46 am »
I had the new engine fitted in today and the car was started for the first time, we let it idle for about 10 mins. All good no smoke bangs or anything wierd, when ready to go on idle I revved the engine up to about 2.5 rpm and then on the trip computer the warning light came up saying STOP! Oil pressure and to switch off the engine, I did so immediately and left it as it is.
This is what maybe causing it, when the engine was being fitted the original loom (from old engine) was being used and everything wired up except the oil pressure sensor from the new engine, so what they did was used the old sensor from my AXX engine on to the new one, could the problem mean the old sensor is not compatible with the new engine?
This was around 5pm so had to leave it with them again and need to wait till Monday to see what happens,
Can anyone shed some light on this problem?
I did use the search thread and nicks write up on the oil line came up but am just trying to figure out about any differences these sensors would have between a engine with k03 and a engine made for a k04
« Last Edit: June 17, 2012, 01:25:33 am by Sammy »
GTI MK5 with all the gooodies
K04 power going on soon!
Offline Sammy
Re: Oil pressure warning light switch off engine!
« Reply #1 on: June 17, 2012, 10:22:50 am »
Someone help please !
Offline vRSAlex
  • -Receive: 253
« Reply #2 on: June 17, 2012, 11:17:26 am »
Why couldn't you use the pressure sensor from the new engine?  Did you fit a new oil filter and oil?
Follow AKS tuning on Facebook
Offline Sammy
« Reply #3 on: June 17, 2012, 11:19:05 am »
I was told it did not fit on to the existing loom, And yes new oil and filter was used Alex
Offline 56OctyVRS
  • -Receive: 72
« Reply #4 on: June 17, 2012, 11:20:40 am »
Has the oil level been checked to see if its above minimum? Also I would try and unplug and plug in the sensor to see if its fitted  correctly. I cant see there being different types of oil pressure sensors for different engine codes.
Offline Sammy
« Reply #5 on: June 17, 2012, 11:24:25 am »
On Monday I will know if the sensor was fitted correctly or not it could have easily been missed out, Just wanting to find out if there are dfferent sensors on these, But then again it probably is as I have already been told by them that the new sensor did not fit! lol
Oil was filled to the max
« Last Edit: June 17, 2012, 11:26:03 am by Sammy »
« Reply #6 on: June 17, 2012, 11:26:05 am »
Your having no luck with the car mate
Offline Sammy
« Reply #7 on: June 17, 2012, 11:26:48 am »
True Monday will tell...
Offline Sammy
« Reply #8 on: June 17, 2012, 12:36:18 pm »
Can someone that can get hold of part numbers see if there are any differences to the pressure sensors between a cupra/S3 engine and standard gti?
Would it be ok to get the new sensor spliced on to my original loom?
Offline martziniuk
« Reply #9 on: June 17, 2012, 06:44:59 pm »
From what I can make out the AXX engine code came with either a 1 pin or a 2 pin sensor, the BWA and S3 engine come with a 2 pin sensor but both are 1.2-1.6 bar so it should work fine. Maybe replace the sensor or your pick up is blocked?
Offline Sammy
« Reply #10 on: June 17, 2012, 11:17:13 pm »
Yeah it was something like that, different pins in the sensors which I why it didn't fit, hopefully it is just the sensor or a sensor clogged up, if not the oil pick up will be checked next, where is this located and is it hard to do?
« Reply #11 on: June 17, 2012, 11:23:23 pm »
think Nick from r-tech had a mk5 gti that had a blocked oil pick up--take the oil sump of a it should be there
Offline Sammy
« Reply #12 on: June 18, 2012, 12:26:14 am »
Yes I have read that thread I am going to try that after this sensor is checked out properly, will let you know how it goes fingers crossed its minor!
Offline Kano2021
« Reply #13 on: August 27, 2025, 02:58:27 pm »
So what was the conclusion on this as I am going through the exactly same thing, AXX engine loom with BWA engine swap.
Did you end up getting a 1 Pin Sensor and did it work? Or did you do some kind of wiring alteration?
Also did your horn come on when in Ignition 1 before start? If so what did you do about it?
Offline GVK
  • -Receive: 76
    • GVKmotorsport
« Reply #14 on: August 27, 2025, 07:58:24 pm »
13 year old thread, doubt they are around here any more.
