Author Topic: Rear inner tyre wear, lowered with walk  (Read 1736 times)
Offline Ducky76
« on: July 06, 2012, 12:37:33 pm »
Hi age old question but is inside edge wear inevitable /or  needed when my car has been lowered and with walk fitted , cos just fitted 19 and don't want 2 be replacing early realy , the fronts wear fine just rears , so is it a case of camber due 2 lowering or dunno  education needed please assist cheers andy
Re: Rear inner tyre wear, lowered with walk
« Reply #1 on: July 06, 2012, 12:39:46 pm »
i have no wear on mine running 19" wheels on--get the cats and camber done
Offline Ducky76
« Reply #2 on: July 06, 2012, 12:49:36 pm »
What's cats ? And will 4 wheel alighnment sort it or is any sort of camber adjustment  or included usually cheers mate
« Reply #3 on: July 06, 2012, 04:03:00 pm »
oops i meant cast and camber :ashamed:
Offline Ducky76
« Reply #4 on: July 06, 2012, 05:57:08 pm »
Ha ha ok I googled it couldn't find owt yea went and had 4 wheel alighnment done was 4 mm out that maybe due 2 walk but any way should be running straight and true with no adverse wear
Offline alackofspeed
  • -Receive: 24
« Reply #5 on: July 06, 2012, 07:12:48 pm »
Toe and camber? Not caster?
Offline Matto
  • -Receive: 116
« Reply #6 on: July 06, 2012, 07:18:20 pm »
From what I have read on here my understanding is the front only has adjustable toe, (having WALK increases castor) and on the rear there is toe and camber adjustment.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #7 on: August 09, 2012, 01:04:32 am »
The WALK doesn't increase tyre wear as it only increses caster. Caster dosen't do any harm to tyres at all.
Reduce camber, increase toe in and swap wheels front/rear frequently !!
« Last Edit: August 09, 2012, 11:12:55 am by the bruce »
"You get what you pay for."
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=s2vli8ov6lpq6vk0isi561gn5u&/topic,19740.0.html
« Reply #8 on: August 09, 2012, 01:10:59 am »
Your talking about the rear tyres here?
Get your alignment sorted out. Ive had 2 sets of tyres go funny on mk5 golfs because of poor alignment.  :happy2:
