All Things Mk5 > Mk5 General Area
Gti Vs Edi30 - Differences
Teutonic_Tamer:
--- Quote from: danishmkvgti on June 01, 2009, 08:52:26 pm ---
--- Quote from: zub-gti on May 28, 2009, 12:11:13 pm ---Not getting this;
If the edition30 engine is identical to the GTi apart from the turbo, surley the GTi has the same tunability once you install the bigger turbo ?
Right ???
and miltek do a 3" and 2.5" DP but what is the dia of the oem unit ?
--- End quote ---
From golfmkv.com forum, ED30 Engine =S3 engine, except for dv location in left drive cars
http://www.golfmkv.com/forums/showthread.php?t=29117
--- End quote ---
Not quite true. Whilst the Ed30 and S3 share the same uprated block and rods, the S3 has much stronger pistons, and more agressive cams - and it is the S3s pistons which are key to it being tunable to 400+ bhp
Msportman:
--- Quote from: Teutonic_Tamer on June 30, 2009, 01:23:55 am ---
Right ???
--- End quote ---
--- End quote ---
--- End quote ---
What are differences in duration on the cams?
Cams on an normally aspirated car usually give the output higher up and give a slightly higher output. Didn't think they made a huge difference generally on turbo cars.
I used to run split duration 276/268 Schricks on my old valver then went to 304 schricks. The power is shifted and increased but you don't get 20-30 bhp increases.
danishmkvgti:
I stand corrected then :happy2:
I'll never be to old to learn new things :wink:
bwen:
A slight bump to the thread but I found this link quite useful when comparing the different engines: http://www.my-gti.com/546/differences-between-vw-golf-edition-30-vw-golf-pirelli-audi-s3-and-seat-leon-cupra-r-engines
DaveB@Vagbremtechnic:
From a manufacturing point of view it just makes you wonder why they would change the gudgeon pin for one GTi engine and not the other, I mean what must be the cost implications - pennies. It does make you wonder whether VW are building these things with longevityy in mind or aftermarket tuners!
Navigation
[0] Message Index
[*] Previous page
Go to full version
