Author Topic: Tyre wear, inner and outer edges.  (Read 10187 times)
Offline Mandy
  • -Given: 95
  • -Receive: 94
« on: July 20, 2012, 09:02:05 am »
What does it mean if both rear tyres have tread as follows:
Outer:   Middle:    Inner:
7mm     8mm       7mm
Does it mean they need to be inflated a bit more? (Currently 37psi).
 :smiley:
Offline Apollo
  • Middlesbrough
Re: Tyre wear, inner and outer edges.
« Reply #1 on: July 20, 2012, 09:03:37 am »
The wear would indicate UNDER inflation ...
« Last Edit: July 20, 2012, 09:06:05 am by Apollo »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=mrrs0p5ntcrkka89h8mbfj597i&/topic,19740.0.html
« Reply #2 on: July 20, 2012, 09:06:58 am »
The wear would indicate OVER inflation ...
Wrong way around :happy2:
Sounds like  a fraction under inflation mandy... but 37PSI is correct!  :confused:
I would expect some variation over the width of the tyre.
Offline Apollo
  • Middlesbrough
« Reply #3 on: July 20, 2012, 09:08:31 am »
Yeah have corrected and added a pic ......I cant multi task - Dunking my bourbon into my coffee and typing/thinking at the same time......epic fail  :fighting:
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #4 on: July 20, 2012, 09:09:23 am »
Thanks, I thought it meant that,
It's not on my golf but my bf's, maybe he should try 39psi on the rears?
« Reply #5 on: July 20, 2012, 09:10:55 am »
.... i wouldnt do that. More air in rear tyres = potentially less grip = into a tree backwards  :signLOL:
What tyres are they mandy?
Offline Apollo
  • Middlesbrough
« Reply #6 on: July 20, 2012, 09:11:55 am »
Inside the fuel cover is a sticker with tyre pressure on it - For a standard Mk5 GTI its 2.40 bar = 35 psi without passengers/load
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #7 on: July 20, 2012, 09:15:10 am »
 :signLOL:
I think they are some sort of Falkens...
« Reply #8 on: July 20, 2012, 09:17:39 am »
Ahh.... Falkens are awful and in my experience they wear badly and unevenly. Leave the pressure as stated in the fuel cap (as apollo said)
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #9 on: July 20, 2012, 09:26:55 am »
Ah ok, thanks to you both. :happy2:
Offline RENNTAG
  • Premium Performance Parts
« Reply #10 on: July 20, 2012, 12:26:43 pm »
Yes, i would say its the falkens.
I currently have falken FK425's  :ashamed: and have been getting more wear on the edges than i should. and not down to alignment as this has been done twice in the last year due to suspension mods.
Offline tony_danza
  • -Receive: 112
« Reply #11 on: July 20, 2012, 12:38:57 pm »
It's because the tyre wall is soft and it deforms and scrubs at the edges on cornering, rather than using the whole footprint. sh*t tyre basically.
Sideways yo!
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #12 on: July 20, 2012, 12:56:11 pm »
So is it worth inflating it up to 39psi or just leave it as it is?
« Reply #13 on: July 20, 2012, 01:04:22 pm »
It's funny. This is the only forum where you can slate falken tyres and not get shot down for being a hater. :-)
Id leave the pressure as is Mandy you don't want over inflation. Just hope they wear down fast, then replace with decent tyres.
Offline tony_danza
  • -Receive: 112
« Reply #14 on: July 20, 2012, 01:30:38 pm »
Leave them alone, 1mm isn't bad considering.
Sideways yo!
