Author Topic: right mix for snow foam  (Read 7868 times)
« on: September 03, 2012, 11:31:56 pm »
i can never get the mixture right for the snow foam but i was advised today to put a inch of snow foam in the bottle and fill up with water
Offline Trekmeister
  • Golf GT 140
Re: right mix for snow foam
« Reply #1 on: September 04, 2012, 07:08:03 am »
I dont know if I was doing something wrong but I used autoglym snow foam which is ready mixed, filled the bottle and blasted it on, got a good thick covering but wasn't impressed with what it removed. A blast of water from the pressure washer seemed to do a similar job. Cant remember the make of the attachment i have but it looks the same as yours and cost nearly £50.
« Reply #2 on: September 04, 2012, 07:11:21 am »
You need to fiddle with the settings. I also found different snowfoams came out differently. Autobrite magifoam seems to foam the best.
« Reply #3 on: September 04, 2012, 08:13:43 am »
That's what I've done from day one!
I've got the cherry foam and the mix is just right at 1"  :happy2:
Have you tried using hot water in the bottle too? Works great  :wink:
Offline Jaywoo-GTI
  • -Given: 38
« Reply #4 on: September 04, 2012, 10:15:50 am »
I do the same as described but top up with warm water, and use the foam lance at MAX foam and leave it at that,
I have heard that running it through with some APC cleans the lance and makes it perform better if your having trouble.
« Reply #5 on: September 04, 2012, 10:35:17 am »
If you're having trouble, it's usually because the gauze that creates the foam is caked up and needs cleaning. I wouldn't expect that in a brand or near new lance.
Offline Horatio
  • -Receive: 39
« Reply #6 on: September 11, 2012, 09:26:02 pm »
Pressure? Maybe unrelated, but I tried this with my dads Karcher 3.8 and the foam is magnificent! Bought a Nilfsk for 50£ at argos and the foam is considerably laking. Used same amount of SF as well  :sad1:
« Reply #7 on: September 11, 2012, 09:28:39 pm »
Less likely to be pressure in that case and more likely to be flow rate. TBH I used my lance with a karcher 2.02 (size of a small portable stereo!) and that produced a good foam.
Offline Baz300
« Reply #8 on: September 11, 2012, 11:15:21 pm »
I have the same snow foam lance as the picture above and a nilfisk £50 pressure washer too and get good foam
I was recommended meguiars hyper wash by polished bliss when I bough the lance
http://www.polishedbliss.co.uk/acatalog/meguiars-hyper-wash-cat2.html
I put an inch in and top up with hot water and give it a good mix before using it
I have the regulator set very low
Offline Frodo-anni
  • -Receive: 45
« Reply #9 on: September 12, 2012, 11:24:19 am »
1" of snow foam & 1" of megs hyper wash + hot water = Narnia  :P
Have mine set on full as if i dont i get sod all out of it, had it a few years now, so maybe an issue with it.
mk5 GTI Edition 30 DSG No0391
« Reply #10 on: September 12, 2012, 12:24:07 pm »
You may need to clean the gauze inside. It can get clogged up with scum.
Offline nads1_uk
« Reply #11 on: September 14, 2012, 07:06:40 am »
when you've finished snow foaming what do you do with what is left in the bottle - throw it away or can it be kept to do another car at a later date?
Andy
« Reply #12 on: September 14, 2012, 07:21:02 am »
I normally keep it for the following week. I normally have half a bottle left and is enough to do the car again. You could always adjust the quantities you use so you have almost nothing left after foaming the car.
Offline synchronize
« Reply #13 on: September 18, 2012, 09:10:25 pm »
This  :happy2:
