All Things Mk5 > Performance Modifications
Ko4 up grade
<< < (2/2)
Dv21:
CHEERS BACILLUS I GUESS ILL BE PUTTING THEM ON EBAY THEN  :happy2:
Evan@APR:
Hey DV21
Consider that most remappers account for the S3 injectors instead of the RS4 options as you have previously discussed unless you're going for a completely custom map. And then again the spray pattern isn't optimal for this head. APR offers a K04 remap for your vehicle and I'd advise you upgrade to an RS4 fuel pressure relief valve to get the maximum from your vehicle with the HPFP and injectors.
Details about the kit and remap can be found here: http://www.goapr.co.uk/products/turbo_trans20t_k04.html Please note, the remap can be purchased separately of the kit (£499+VAT) and will function as advertised if the components match.
If you are considering the APR remap avenue, we have two distributors you seem to sit conveniently between.
Gwent VW Audi Centre
Unit 19-20 Estuary Road
Queensway Meadows, Newport NP19 4SP
01633 281 222
gwentvw.co.uk
And
Tuningwerkes
40 Haling Road
South Croydon CR2 6HS
020 8681 0208
tuningwerkes.com
While you're at it, may I recommend you check out our fuel pump? Fully rebuilt, tested and comes with a lifetime warranty! :)
http://www.goapr.co.uk/products/fsi_fuel_pump.html
If you have any additional questions, please don't hesitate to reach out.
GO APR!
Hedge:
You could go to JKM as they have several successfully converted K04 cars already running.  :happy2:
james:
cheaper to take your engine out and put a full s3 engine and sell your old engine
i worked that out the hard way  lol.
JMP:
--- Quote from: james on October 26, 2012, 08:08:50 pm ---cheaper to take your engine out and put a full s3 engine and sell your old engine
--- End quote ---
By the way, do you know what are the changes needed in the car to make this happen (in detail)? And what software should be used, is the change tailored around S3 or GTI sw? IIRC boost sensor range is different between the engines.
Navigation
[0] Message Index
[*] Previous page
Go to full version
