Author Topic: What power should I be running with my mods ....  (Read 4178 times)
Offline jamiep91
« on: January 07, 2013, 09:19:47 pm »
Basically my car has a ko4 turbo, forge fmic, s3 injectors, air filter down in the bumper not sure of make, forge DV and a Sachs clutch . Apparently it was running 340 bhp but It developed a misfire so I took it to jabbasport and they told me a remap would sort it but it hasn't and they told me it came out at 310bhp, told me they will send the dyno printout in the post as they was out of ink but I still haven't received it after 4-5 weeks and a phone call.
(Missed out full milltek and hpfp)
Should I be at more power than that and where do I stand with getting some money back as they said I need a remap but it hasn't fixed it ? Any opinions/thoughts would be great :)
« Last Edit: January 07, 2013, 09:22:54 pm by jamiep91 »
Offline zerolag
  • Ass of Ennis
Re: What power should I be running with my mods ....
« Reply #1 on: January 07, 2013, 09:23:13 pm »
Does it have an upgraded HPFP?
What does the RR map look like, can you supply?
Have you put it on VCDS yet?
« Reply #2 on: January 07, 2013, 09:24:13 pm »
Who's map was on there in the first place?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=suko2odeq2i2p5iqv4sq0uop38&/topic,19740.0.html
« Reply #3 on: January 07, 2013, 09:24:14 pm »
Just remind me to NEVER take my car to Jabba sport!!  :fighting: :fighting: :fighting:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: January 07, 2013, 09:25:56 pm »
I think you need to do some research before buying modified cars. To make 340bhp it MUST have been remapped. So it sounds like you have paid for another remap  :surprised:
If a car develops a misfire it's probably down to either a spark plug, coil pack, injector, PCV or carbon buildup.
Ive never heard anyone suggest a remap as a cure for a misfire.
Shame on Jabbasport for suggesting a ludicrous idea  :fighting:
With your set up you should have 340bhp ish (depending on dyno). I'd go straight back there and get your money back.
Graeme
« Reply #5 on: January 07, 2013, 09:30:55 pm »
jabba sport strikes again .. :rolleye:
Offline jamiep91
« Reply #6 on: January 07, 2013, 09:45:50 pm »
It was a revo on there before done by amd Essex , I don't have a printout for anyone to look at as they still haven't supplied one , I'm really p****d off .
I changed the plugs and it was still there and while jabbasport had it they swapped the coils round and it was in cylinder 2 all the time apparently so not the coils. I needed the car at the time and they had it 2 days so I couldn't leave it there again. I think I will be taking a trip there Saturday.
Yes it has a uprated hpfp but I have tested the DV yet as I'm not sure how .
Is there something in the inlet manifold that can stick from carbon build up or is that somewhere ?
« Reply #7 on: January 07, 2013, 09:50:11 pm »
So they took Revo off and put one of their own efforts on.  :stupid:
At least go back and get them to flash it back to stock so as you can get your Revo reapplied.
Get somewhere that knows what they are doing to look at it.
« Reply #8 on: January 07, 2013, 10:07:41 pm »
ask for a refund as it didn't cure your problem like they advised it would
« Reply #9 on: January 07, 2013, 10:43:07 pm »
^^^^^This^^^^^
If you have checked out the coilpacks and spark plugs then the next port of call are the injectors. Are you sure they are S3 injectors? I've seen a car with a K04 upgrade and when the injectors were taken out they were stock K03 ones. If they are S3 injectors then swap the one out of number two for a new one. If it cures it I'd suggest taking the head out and inspecting the piston. I've also seen the damage a faulty injector can do to a piston. Before this you could have a leak down test to see if you are losing compression too. This would show if the valves aren't seating correctly through carbon build up and it isn't a hard test to do.
It is all a bit of a bind, but will pay off in the end.
Offline jamiep91
« Reply #10 on: January 08, 2013, 12:35:15 pm »
^^^^^This^^^^^
Thanks I'm pretty sure they are s3 injectors yes , I need to find another specialist who will do this work for me who would you lot recommend that wont rip me off
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #11 on: January 12, 2013, 04:24:41 pm »
I was considering a map at Jabbasport but after that read I'm not so sure  :confused:
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
« Reply #12 on: January 12, 2013, 04:31:58 pm »
i would go else where and spent your money on a company who will look after you and not interested in just your money
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
« Reply #13 on: January 12, 2013, 04:47:08 pm »
Is this every1s impressive of jabbasport or have you just heard a lot of horror story's, every1 my way recommends them?
« Reply #14 on: January 12, 2013, 05:24:44 pm »
....There's been a lot of folks on car forums and over a long period of time too, who have reported bad experiences with Jabbasport. So, it's sensible to take notice.
Just hearing how they have dealt with your car is enough to put me off quite frankly.
