Author Topic: ticking noise when warm  (Read 8207 times)
Offline samiep
« on: January 09, 2013, 03:21:48 pm »
hello
so iv just recently brought a mk5 gti it has 85000 on the clock and iv noticed a ticking noise when its warm i can hear up to about 2000rpm inside and outside the car,  any ideas what this could be? much appreciated sam
Offline swgti
  • -Given: 28
Re: ticking noise when warm
« Reply #1 on: January 09, 2013, 03:39:58 pm »
They all do it, something to do with the injectors IIRC, you'll see loads of threads on here with people wanting to know why their car sounds like a diesel.
If it's a knocking you may be looking at something totally different.
Offline samiep
« Reply #2 on: January 09, 2013, 03:59:01 pm »
ahh ok yeah i had a look at other threads just wanted to check, mine sounds just like a diesel, is there any way to make it more quiet?
Offline gigolo456
« Reply #3 on: January 09, 2013, 04:04:36 pm »
turn the ignition off!!  :jumpmove:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #4 on: January 09, 2013, 04:35:08 pm »
If it's just a constant light ticking, don't worry about it - they all seem to do it. Get on with enjoying a great car. :smiley:
'07 Red manual
Offline AndyS
« Reply #5 on: January 09, 2013, 04:36:16 pm »
Low oil presure , could be oil pump blocked or on its way out (happened to mine and needed new engine)  :sad1:
Offline craigy123
  • -Receive: 24
« Reply #6 on: January 09, 2013, 06:25:06 pm »
As said, if its a constant low ticking/clicking noise. It will be your injectors.
PM for details
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #7 on: January 09, 2013, 07:01:35 pm »
hello
..........a slight ticking noise is normal,but if it's very loud it could be the small cam chain & tensioner  :scared:.What engine code mate? does it start AXX?.
Offline Lone_Par
« Reply #8 on: January 09, 2013, 07:18:52 pm »
Could be the cambelt? I had this, saw all the threads about it being normal, then eventually got the belt and water pump changed and the ticking stopped!!
Offline samiep
« Reply #9 on: January 09, 2013, 07:26:36 pm »
it sounds a bit to loud to be normal, it is due a cambelt and water pump so ill get that sorted and see if that sorts its :stupid: cheers for the help  :driver: :driver:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #10 on: January 09, 2013, 09:22:28 pm »
..........there is a small cam chain as well(other side of engine to rubber cam belt).My last GTI was very loud on tick over when warm AXX engine code & it had to have the cam chain & tensioner replaced.
Offline Daveh
« Reply #11 on: January 09, 2013, 11:10:41 pm »
What Gene said. I had the cam chain and tensioner changed on mine as it was 'knocking' on tickover when warm.
Offline JagGTi
« Reply #12 on: January 10, 2013, 02:46:22 am »
Have you checked your cam follower? Mine was worn and meant the cam shaft needed changing which alex did at aks. Ever since then the diesel sound I used to get once engine was warm has gone and sounds fine. a 2005 gti axx engine on 67k
Offline samiep
« Reply #13 on: January 10, 2013, 08:11:39 pm »
no haven't checked the cam followers i dont thinks its been replaced, iv booked in with a mate for feb(skint till then :confused:) for a full check over and to see if its anything bad
