All Things Mk5 > Performance Modifications
Standard clutch with a stage 1 map on an ed 30?
<< < (2/2)
the bruce:
--- Quote from: Tortaruga on March 11, 2013, 07:30:29 pm ---You need to find out what torque the oem pressure plate will handle. If the torque on your animal is higher then you'll need an uprated clutch.
--- End quote ---
Mk.V GTI started in 2004. No need to find anything out. All data is already well known.
Clutch is specified at 350 Nm +10 % = 385 Nm. Same with ED30/Pirelli. If you run more
than this, you will need an uprated clutch, earlier or later.
BTW, you cannot specify a torque to a pressure plate, just for a pair of disc + pr. plate.
 :wink:
skard:
My stage 1 ED30 has a new OEM clutch & DMF - is the DMF ok to use with an uprated clutch long term when going 2+?
PDT:
The aggression of the torque curve is also a factor, I have tuned many cars on the dyno that have had slipping clutches when requesting a specified amount of torque during mapping that have had the slip issue resolved by altering the ramp of the torque curve, but still requesting the same peak torque.
damoegan:
--- Quote from: skard on March 23, 2013, 09:59:21 am ---.....is the DMF ok to use with an uprated clutch long term when going 2+?
--- End quote ---
Yep  :happy2:
the bruce:
--- Quote from: skard on March 23, 2013, 09:59:21 am ---My stage 1 ED30 has a new OEM clutch & DMF - is the DMF ok to use with an uprated clutch long term when going 2+?
--- End quote ---
Most likely - yes.
--- Quote from: PDT on March 23, 2013, 10:55:42 am ---The aggression of the torque curve is also a factor, I have tuned many cars on the dyno that have had slipping clutches when requesting a specified amount of torque during mapping that have had the slip issue resolved by altering the ramp of the torque curve, but still requesting the same peak torque.
--- End quote ---
Agree. A more aggressive curve will cause the DMF to hit to the stop. With a DMF I'd prefer a smooth torque curve.
Navigation
[0] Message Index
[*] Previous page
Go to full version
