Author Topic: Power tools!! Mitre Saws.........  (Read 6485 times)
Offline GE90
« on: March 11, 2013, 09:44:48 pm »
Hi All
Finally looking at getting a mitre saw. However, I cannot immediately see why the sliding versions cost so much more! Only a keen DIY'er, but want to get some compact and still able to cope with larger tasks.
Would really be grateful for any views on these:
http://www.toolstop.co.uk/bosch-pcm-7s-1200w-diy-sliding-mitre-saw-240v-p59290
http://www.toolstop.co.uk/bosch-pcm-8-s-1200w-diy-bench-top-compound-sliding-mitre-saw-240v-p7072
http://www.screwfix.com/p/dewalt-dw713xps-250mm-mitre-saw-240v/69195
These are max budget. It just seems that the Dewalt can cope with similar thickness with sliding??
Thanks in advance, cheers
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Power tools!! Mitre Saws.........
« Reply #1 on: March 11, 2013, 09:53:11 pm »
it will depend on what you are going to use it for
A sliding one can be used to trench
I've always used Dewalt and they have been good for their saws
Cluster and Key coding
Location Great Yarmouth
Offline doylebros
  • -Receive: 310
« Reply #2 on: March 11, 2013, 09:56:51 pm »
Hire and save yourself the worry if it's not for anything other than DIY,as there's no single perfect tool - Dewalt is the most trouble free product we've bought for everyday use for the price though!
Offline GE90
« Reply #3 on: March 11, 2013, 09:58:55 pm »
Ah trench.......? Initially just for skirtings, batons etc, but will need to cope with joists when I start putting storage up in the roof pitch of the garage! So sliding version might not be necessary?
Thanks v much
« Last Edit: March 11, 2013, 10:00:35 pm by GE90 »
Offline GE90
« Reply #4 on: March 11, 2013, 10:03:15 pm »
Thanks, never thought about hiring, but will be a birthday present, and just handy to have to hand when I am doing odd timber jobs.
Offline andyR43
« Reply #5 on: March 12, 2013, 08:01:01 am »
Out of those listed it would have to be the DeWalt, Bosch power tools don't last. You should be looking at DeWalt, Makita or Hitachi.  :happy2:
Keeping it original..............or not!!
Offline alanbgt
« Reply #6 on: March 12, 2013, 08:03:12 am »
My De Walt has been extremely solid.  Bosch one was not.
If you have lots of work for it, I would say the higher price for the De Walt is a good investment.
Alan
Offline GE90
« Reply #7 on: March 12, 2013, 08:17:33 am »
Thanks Guys
My only concern with the Dewalt is that it is non-sliding, and the Bosch do slide. Just worried that once I start using it more, I might realise the benefit of the slide function....??? Still not sure what the slide does yet!!??
Thanks all
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=7khcbhjsi1rlaefp91b6s04qh5&/topic,19740.0.html
« Reply #8 on: March 12, 2013, 08:19:45 am »
I got one from b&q lasted year and its fine for 99 quid. Think it's made by a company called rage.
« Reply #9 on: March 12, 2013, 08:20:30 am »
With the slide you can cut wider items such as flooring.
Offline andyR43
« Reply #10 on: March 12, 2013, 08:29:05 am »
The slide allows you to cut wider boards for a given blade size. As you can see in the links you've provided the 2 Bosch saws have smaller blades than the DeWalt. For the home DIY'er an Evolution Rage sliding saw (as mentioned by RICHWIG83) is a better buy than a Bosch and will last better.
« Reply #11 on: March 12, 2013, 08:49:11 am »
Rage 3-S Evolution  are worth their weight in gold. £99 Screwfix.
The Thin Multi purpose Blades are Amazing, and they are only £20 to replace, but they last ages.
(Dependant on how much Metal you cut through)
I have a £700 Bosch 305mm Mitre Saw that I used for work, but I bought the Rage for smaller jobs.
Since I've had the Rage saw, I've only ever used the Bosch for things like 4x4" decking posts etc. The Rage is So handy and portable.
The Rage is awesome for Skirting and Door Archi's etc. Even with its little Blade it will cut 200mm on a 45'.
You will struggle with wet joists if they are over 6x2" but tbh the Rage 3-S isn't really the tool for that sort of work.
If you get the Rage 3-S you WILL love it.
http://www.evolutionpowertools.com/uk/build/rage3s.html
« Reply #12 on: March 12, 2013, 08:55:53 am »
For £200 you can get the Bigger Rage 3.
Tbh I think this is the one for you mate.
It'll do almost anything...including the bigger stuff.  :wink:
Check out the video here....
http://www.evolutionpowertools.com/videos/rage3_video.html
Offline GE90
« Reply #13 on: March 12, 2013, 07:17:25 pm »
Thanks all. Monte, really like the look of your suggestions, but there seems to be 2 versions of the 3S at Screwfix. Seem the same power etc, perhaps a new model. This one seems to have guides and a dust bag, but £169! ????
http://www.screwfix.com/p/evolution-rage3-s-210mm-sliding-mitre-saw-240v/70961
http://www.screwfix.com/p/evolution-rage3-s-210mm-sliding-compound-mitre-saw-240v/60839#
I can get the Dewalt in my original post for £130, but the Evolution seems to be the one to go for still? Plus I've always wanted an Evo!
Offline beetie
  • -Given: 34
« Reply #14 on: March 12, 2013, 08:07:56 pm »
As said by others, those Bosch ones are very cheaply made. Being green they are diy use (flimsy), for decent Bosch you need the professional range which are blue.
