All Things Mk5 > Mk5 General Area
Mk6 flat bottom steering wheel
curley:
Well done that man. It does look great much better than before.
ollie288:
Thanks :happy2: I cant wait to get it fitted!
x5pea:
you can get these on ebay for around £400, they arent mk6 GTI ones tho, most likely from the new passat cc or scirocco but essentially they look the same. GTI has red stitching and i think is only orderable if you have a GTI
mortygttdi:
Mk6 GTD has the same wheel infact the only thigs it hasn't got over the gti is the wheels, exhausts and engine :confused: every thing else is GTI spec.
winrya:
--- Quote from: mortygttdi on August 15, 2009, 11:01:21 pm ---Mk6 GTD has the same wheel infact the only thigs it hasn't got over the gti is the wheels, exhausts and engine :confused: every thing else is GTI spec.
--- End quote ---
Can't remember if it was evo mag or top gear but they said it has different suspension setup and as such doesn't drive anywhere near as well as the gti
Navigation
[0] Message Index
[*] Previous page
Go to full version
