Author Topic: Got a fuel pump, updated with fitting pics  (Read 14600 times)
Re: Got a fuel pump
« Reply #15 on: August 14, 2009, 03:55:59 pm »
Should give you that extra power you crave Gaz :driver: :signLOL:
Anything after stage 2+?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Got a fuel pump
« Reply #16 on: August 14, 2009, 09:57:17 pm »
nathan can you guess whats coming ?
 :angry015:
Red ED35 5dr DSG
BLOG | BUILD
Offline gazbutS3
Re: Got a fuel pump
« Reply #17 on: August 14, 2009, 11:08:24 pm »
probably a clutch :laugh: :laugh: :laugh:
Re: Got a fuel pump
« Reply #18 on: August 14, 2009, 11:16:43 pm »
 :signLOL:
You may be right! :driver:
Offline gazbutS3
Re: Got a fuel pump
« Reply #19 on: August 14, 2009, 11:27:57 pm »
I'm sure of it,  :laugh:
sayin that the 08 on S3's had a sachs clutch as std instead of the LUK item that was fitted earlier, so I'm hopin it maybe a bit stronger, I do try to be nice to the clutch, not to many hard starts and I try not to load it to much in the higher gears :happy2:
Re: Got a fuel pump
« Reply #20 on: August 14, 2009, 11:30:39 pm »
Naaaaaaa,
I just know you'll not be able to resist giving it some stick now you have the power :wink:
Offline gazbutS3
Re: Got a fuel pump
« Reply #21 on: August 14, 2009, 11:32:58 pm »
I'm a reformed character since the bump, steady all the time :smiley:
Re: Got a fuel pump
« Reply #22 on: August 14, 2009, 11:38:26 pm »
I thought that would have been a wink and not a smile :rolleye:
Offline gazbutS3
Re: Got a fuel pump, updated with fitting pics
« Reply #23 on: August 16, 2009, 10:17:49 am »
ok fitted the pump yesterday, quite an easy job, took about an hour, but I was in no rush
first you need to remove the engine cover, we all no what a pain in the @rse that can be, just give it a sharp tug :smiley:
then you'll see the pump on the righthand end of the engine
make sure you release the fuel pressure from the schrader valve
Offline gazbutS3
« Reply #24 on: August 16, 2009, 10:27:39 am »
continued :smiley:
disconnect the inlet and out let underneath, then disconnect the 2 electrical plugs and the remove the 3 bolts holding the pump to the engine and remove the pump
I got a replacement cam follower bucket as I thought I'd change it while it was in bits but as you can see from the pictures there was no signs of wear at all, the old 1 is on the left this is 14000miles old
fitting is the reverse of removal,  make sure you put a touch of moly grease on the cam side of the follower to help bedding in
New pump fitted, The pump comes with full instructions and is fairly straightforward, thanx for looking
Offline NB07
« Reply #25 on: August 16, 2009, 10:43:56 am »
well done on the fitting  :happy2:
it looks exactly the same apart from the APR sticker! looking forward to reading the results  :smiley:
Offline gazbutS3
« Reply #26 on: August 16, 2009, 10:46:04 am »
externally it is the same as stock :smiley:, won't get the true benefits untill the stg 2+ software is fitted this week :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #27 on: August 16, 2009, 10:52:30 am »
Are you feeling the benefits now Gaz?  I ran my pump with Stage 1 software and found it much improved.
Couple of observations -
I know it's not in any of the supplied instructions but the factory repair manual does specifically state to have Cyl 1 at TDC before fitting a pump.
Make sure not to open the drivers door with the fuel pipes removed, you'll get wet.
Be careful if the door has been opened or the car run in the previous couple of hours as the system will be charged with pressure.
Not sure about the moly grease, is that in the APR instructions??  The follower is in the main engine oil path so my understanding is any lube on install should be engine oil only so as not to contaminate the engine oil.  One of the problems with the dodgy batches of internals was fuel passing through the shaft seal and making its way back to the sump.
Stu...
Offline candy turbo
« Reply #28 on: August 16, 2009, 10:52:50 am »
is there any difference now mate ? does it feel any better ?
Offline gazbutS3
« Reply #29 on: August 16, 2009, 12:50:54 pm »
Yes, the moly grease tip is in the APR instructions, its only a very small amount, a smear at the most
""if you are using a new cam follower, be sure to use some moly grease on the camshaft side of the follower for intial break in", copied from the APR destructions :smiley:
I did put a note about depressurising the system :happy2:, you are supposed to disconnect the battery
It definately does feel more responsive running it with the stg 1 map, thought it was the placebo effect at first but the more miles I did the better it got, maybe adjusting itself a bit
« Last Edit: August 16, 2009, 10:36:10 pm by gazbutS3 »
