Author Topic: Wheels under warranty - where do I stand  (Read 4806 times)
Offline Lynsey
« on: August 20, 2009, 09:48:16 am »
Noticed the GT's last wash at the weekend that 2 of my wheels are starting to go - the dreaded issue with diamond cut wheels!!  Almost spot on timing, 4 months before my warranty is due to run out!
So... there's only 2 wheels that're going so far, where do I stand with VW - if I kick off enough, will they give me a new set or just the 2?  :smiley:
I don't want to go a few months into no warranty time only for the other 2 to follow suit!  :scared:
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
Re: Wheels under warranty - where do I stand
« Reply #1 on: August 20, 2009, 09:49:43 am »
Are any of them kerbed at all? If not, id go for a full set of 4x!!!  :happy2:
#1493
Offline Lynsey
« Reply #2 on: August 20, 2009, 09:55:20 am »
Nope, none of them are kerbed!
Offline Cooper
« Reply #3 on: August 20, 2009, 10:10:46 am »
My dealer was pretty cool about it when I turned up asking about the same thing on my Monza II's about 6 months before my warranty was due to run out and replaced all 4 wheels and centre caps even though 1 of them was fine, they just said the other one will probably start going so we'll just replace all 4! I was chuffed to bits   :grin:
C63
SQ5
« Reply #4 on: August 20, 2009, 12:05:52 pm »
when i have been changing alloys for subura we change all 4 alloys even if only 2 need doing
Offline Edition30
« Reply #5 on: August 20, 2009, 12:56:14 pm »
Are they the original wheels supplied with the car?
MyProtein - MP119633
« Reply #6 on: August 20, 2009, 01:03:16 pm »
So let me get this right  :surprised: Your name is Lynsey and none of your wheels are curbed. I dont believe it.  :chicken:
Only kiddin  :signLOL:
Offline holepunch
« Reply #7 on: August 20, 2009, 01:06:23 pm »
I had no issue getting my 3 of my monza II's replaced with only 3weeks of warranty left.  At the same time I also had the cambelt + tensioner, water pump and timing chain replaced again all covered, but thats another story.
« Reply #8 on: August 20, 2009, 01:36:38 pm »
Could be tricky getting all 4 replaced under warranty. It's not just kerbing but also stone chip damage which can start the worm gradually spreading - In fact, anything which breaks the clear lacquer seal and allows moisture in.
As Edition30 says, it's essential that your original car came from an approved UK VW dealer and with the same wheels originally. I have direct experience of such problems.
Offline Lynsey
« Reply #9 on: August 20, 2009, 01:51:15 pm »
Yes they are the charleston alloys that're optional extras with the GT's - I've had the car since day 1 from factory order!
It can't be stone chip damage either cos it's starting from the wheel centres - the centre caps are also fecked so will need to get these replaced too!
lol this is correct - never kerbed a wheel in my life!  I have kerb paranoia and stay miles away from them lol
« Reply #10 on: August 20, 2009, 01:57:18 pm »
....Stone chips can fly and damage anywhere. I actually witnessed this one happening : -
« Reply #11 on: August 20, 2009, 11:48:11 pm »
It can happen around the recess for the wheel bolts too,you'll get them sorted lynsey
Offline Lynsey
« Reply #12 on: August 21, 2009, 09:56:16 am »
Thanks - hope so!
Gonna take him over the stealers next week on passing - let you know how I get on!
Offline Merlinman
« Reply #13 on: August 21, 2009, 02:15:45 pm »
Keep us posted please, Lynsey - my Charlestons are just shy of two years old (13k) and look perfect - although I knew when I specced them that they were likely to go the way of some Monza 18's, having a similar diamond cut finish.
Reugular washing with Meguiars, dry off with microfibe towel and 3 monthly 3 coat Poorboys is what I've been doing and like you I take a bus to the kerb  :grin:
My previous March '06 Steel Grey GTI which went to Yan on here still has its original wheels as far as I know and I suspect Yan is as fastidious with them as I was; however there seems to be no hard and fast rule with the worm - other than physical damage to the lacquer?
My car's a keeper and if the worm appears after the  warranty expires, I reckon they'd look pretty smart in single colour anthracite?
Good luck on getting yours replaced  :happy2:
