All Things Mk5 > Mk5 General Area
DS2500 pads and Whiteline anti-lift kit
<< < (2/2)
bacillus:
--- Quote from: RedRobin on August 25, 2009, 08:03:26 am ---....
I don't know if the brake pad wear sensors can be VAGCOM'd to accommodate DS2500's (vrStu will know), but it's easy and more reliable to visually check them.
--- End quote ---
Yes you can switch it off in VCDS or do a ghetto fix by shorting the terminals.   :smiley:
RedRobin:
--- Quote from: bacillus on August 25, 2009, 08:27:23 am ---
--- End quote ---
--- End quote ---
....Hi bacillus :smiley: - "switch it OFF" you say - Mine has never been switched off (unless AP Racing did so, which I didn't see them do) and no pad sensor has displayed itself to me.
?? :confused:
DanGB:
--- Quote from: RedRobin on August 25, 2009, 08:44:12 am ---
--- End quote ---
--- End quote ---
?? :confused:
--- End quote ---
same here
bacillus:
If your pads didn't come with the sensor wire then I suspect that they simply shorted the cable that attaches to the pad wear sensor wire. All this does is make a closed circuit like what occurs when using a good pad, fooling the car into believing the pad is ok hence no warning light.
robern2:
I've also been recommended Tarox Rallye+ pads as an alternative, anyone used them ?
Navigation
[0] Message Index
[*] Previous page
Go to full version
