All Things Mk5 > Performance Modifications
VWR brakes
oak_grun:
--- Quote from: danishmkvgti on August 17, 2013, 10:46:47 pm ---
--- Quote from: oak_grun on August 17, 2013, 08:44:11 pm ---
--- Quote from: danishmkvgti on August 17, 2013, 10:34:04 am ---
--- Quote from: oak_grun on August 17, 2013, 10:05:10 am ---^^ anyone running these behind standard wheels?
--- End quote ---
Not possible, the stock ET51 won't allow for use of calipers with pistons on the outside of the disc :smiley:
--- End quote ---
Not even with spacers?
--- End quote ---
You asked if they would fit with the stock wheels, stock isn't spacers. But yeah chuck 50mm spacers behind the stock wheels and you have room for the world behind the OEM wheels :laugh:
I'm sorry but i find that question a bit contradicting, hence the rude answer :happy2:
--- End quote ---
No need really....simple question that was all.....
Back on topic the guy I am purchasing them off says he was running them with 10mm spacers? Anyone able to confirm they will fit with 10mm spacers before I part with my cash.
wigit:
VWR brakes initially came with two bell sizes given the clearance issue
the later VWR kits have there own dedicated spacer in a range of sizes
maybe worth giving VWR a call
Sie:
I've got the caprio based ones with built in 15mm spacer and fit behind my monza II easy also the chap I brought them off had them behind pescera.
So I guess depends if you have bells with spacers or buy some spacer if you got normal ones.
Simon.
Navigation
[0] Message Index
[*] Previous page
Go to full version
