All Things Mk5 > Mk5 General Area
VF Engineering
<< < (3/3)
bacillus:
--- Quote from: jonnyc on August 25, 2009, 09:59:37 pm ---[
Go twintake, awesome stuff..
--- End quote ---
Jonny as you have the  twintake and if you have some spare time, could you please log block 032 (fuel trim) and post the two values. You can do this without starting the car.
Many thanks
jonnyc:
--- Quote from: bacillus on August 25, 2009, 10:17:56 pm ---
--- End quote ---
Many thanks
--- End quote ---
I dont have Vag com but ill do it next time im round my friends house yeah.. Whats the reason for this?
bacillus:
I just wanted to see if the values are within the +/-10% tolerance. Apparently if within tolerance it indicates the MAF is correctly positioned in the intake.
jonnyc:
--- Quote from: bacillus on August 25, 2009, 10:35:25 pm ---I just wanted to see if the values are within the +/-10% tolerance. Apparently if within tolerance it indicates the MAF is correctly positioned in the intake.
--- End quote ---
Ah ok, well if it wasn't then I think that I would be experiencing problems though surely? Anyways ill try and do it for you..
bacillus:
Many thanks...   :happy2:
Navigation
[0] Message Index
[*] Previous page
Go to full version
