Author Topic: hmmm... help  (Read 5161 times)
Offline southy
hmmm... help
« on: September 09, 2009, 05:35:40 pm »
 :confused:
well, I got my car mapped down at edition, love it. however the chap from revo who did it told me that a fault code came up before he put the map on, I also have a forge blow-off spacer fitted, my second service is almost due and I just want to know if I need to remove the blow-off spacer in order to avoid any issues with warranty, or will it be fine?
cheers, southy
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: hmmm... help
« Reply #1 on: September 09, 2009, 06:35:07 pm »
what fault was it
Re: hmmm... help
« Reply #2 on: September 09, 2009, 06:45:01 pm »
As far as I know blow-off valves don't do the 2.0T FSI's turbo system any favours so unless you really want one, it's probably wiser to take it off.
I've just remembered that vrStu used to have one on his Skoda so he'll probably tell me I'm talking rubbish.
« Last Edit: September 09, 2009, 06:46:58 pm by RedRobin »
  • -Receive: 453
Re: hmmm... help
« Reply #3 on: September 09, 2009, 07:18:19 pm »
Nah, you're safe as he should be in the US atm...   :wink:
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: hmmm... help
« Reply #4 on: September 09, 2009, 07:28:44 pm »
what makes you say that? I know every engine reacts differently in a way toblow off valves
Re: hmmm... help
« Reply #5 on: September 09, 2009, 07:36:55 pm »
....I read it somewhere - Doubtless on a car forum (it's all I ever read!) but IIRC it was said by someone who explained why and seemed to know his stuff. Something about the potential for leaks, albeit very small and more about decreasing efficiency.
I'm not 100% sure and that's why I'm hesitant and wrote "as far as I know".
However, Forge offer one so presumably it's been fully tested etc.
Offline Keith@APR
  • -Receive: 36
    • Go APR
Re: hmmm... help
« Reply #6 on: September 09, 2009, 08:57:00 pm »
Our cars use load based engine management systems that meter the amount of incoming air and if its vented to atmosphere, the ecu makes all of its calculations regarding how to operate the engine as though that air was still in the system as its designed to be.
Re: hmmm... help
« Reply #7 on: September 09, 2009, 11:14:40 pm »
....Sorry if I'm being thick, Keith, but does that then mean that the ECU behaves as if there was no whooshy spacer? Or that it's smart and compensates accordingly for a spacer?
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: hmmm... help
« Reply #8 on: September 09, 2009, 11:38:12 pm »
as above, im just as baffled as robin.
Re: hmmm... help
« Reply #9 on: September 10, 2009, 04:38:08 pm »
i was always led to believe that your supposed to use a recirculating rather than an atmospheric too with the FSi
Re: hmmm... help
« Reply #10 on: September 10, 2009, 04:52:07 pm »
....That's right. But Forge offer an additional component called a spacer and which makes whooooshy noises - That's all it does.
Re: hmmm... help
« Reply #11 on: September 10, 2009, 05:01:28 pm »
:chicken: :grin:
Re: hmmm... help
« Reply #12 on: September 10, 2009, 05:10:56 pm »
Offline southy
Re: hmmm... help
« Reply #13 on: September 10, 2009, 06:23:06 pm »
cheers for all the replies, erm i forgot to say that my car is a tsi not an fsi  :P
il take it off regardless
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
Re: hmmm... help
« Reply #14 on: September 10, 2009, 07:41:25 pm »
^^^ So you have the 1.4 twin charger then  :happy2:
